MQTT Interface Should Send LWT on Hub Reboot
  • Hubitat supports an MQTT interface in-box
  • MQTT interface supports LWT messaging
    • LWT support was added in 2.1.2
  • MQTT Interface does not send the LWT message on hub reboots
Arguably the main (maybe ONLY?) purpose of a LWT message is to tell the MQTT broker and its subscribers that the MQTT client is going offline/unavailable.
This is not happening on hubitat's MQTT interface as it does not actually send the LWT message as expected on a hub reboot.
Note that proactively sending a LWT isn't "required" in any standard, so the current implementation isn't "wrong" as the broker typically makes the LWT decision.
That said, many MQTT client/hubs do proactively send the LWT if their parent hardware is going down, and that is what I would like to b considered for Hubitat's MQTT implementation. That's why this is a feature request.
Example connection in a driver - this does not send an "offline" as desired on a hub reboot:
			interfaces.mqtt.connect("tcp://${settings?.brokerIp}:${settings?.brokerPort}",
							   "hubitat_${state.HubId}_${device.displayName}",
							   settings?.brokerUser,
							   settings?.brokerPassword,
							   lastWillTopic: "hubitat/${state.HubId}/${device.displayName}/LWT",
							   lastWillQos: 0,
							   lastWillMessage: "offline",
							   lastWillRetain: true)
Thanks in advance for the consideration!
