I order a C-5 last night and I am preparing for the change over.
I know I can backup/restore my configure and that will save my rules. I got a OTG cable coming per @adamkempenich good advice so I can move my C-4 z-wave stick to my new hub.
That got me thinking....what about the zigbee devices? Is there a better way to add them to the new hub other than to factory reset and reinstall?
Also will that break all my rules that involve zigbee devices?
If you have an HUSBZB-1 on your C-4, which does both Zigbee and Z-Wave (unless you have a second external Z-Wave stick, e.g., in non-North-American markets; the C-4 has no built-in radios, so if you have devices of both protocols, you have something for each), you can move that over to your new hub. Coupled with your hub backup, that should cover both your Zigbee and Z-Wave devices. (That being said, I had bad luck moving a Z-Stick between two hubs once, which should have been easy...not sure if that was bad luck on my part. They were different models, a C-5 to a C-3. I ended up just redoing all of those.)
In the absence of doing that, you can just restore the hub database. Resetting and re-pairing your Zigbee devices to the new hub with the database will cause the hub to recognize them and slide them back into the same "device" they were before. This means you won't have to redo any apps/rules (except Groups and Scenes; go into any group and click "Done," since resetting a Zigbee bulb/plug will also erase its internal knowledge of what Zigbee group IDs it belongs to). In my experience, this is pretty easy--I did that instead of moving the stick from my old hub when I got a C-5. Your level of patience may vary depending on exactly how many devices you have and how easy they are to reset.
May I please ask why? I personally believe the C3/C4 hubs have had fewer issues reported than the C5 hubs (especially considering the C5's network interface issues.) The CPU power, RAM, and storage are the same on both hubs.
I have a C3 as my main Hub (Zigbee, Z-Wave, and Lutron devices), a C4 as an auxiliary hub (mostly cloud integrations), and a C5 hub that I use as my development hub. This has worked very well for my needs.
I suggested it. I had a lot of issues with my C-4 hubs that sounded familiar to what he was experiencing. Ever since swapping them all out to C-5 hubs, everything has been a lot smoother.
The NIC in the C5 hub has had issues with auto-negotiation of speed/duplex for some users' network hardware. Hubitat implemented an automatic fix for this that takes effect within 24 hours of the hub detecting it. There has also been at least one user who determined his C5 hub was generating CRC errors. This was corrected by the Hubitat team via a replacement hub. I have never heard of anyone experiencing these issues with the C3/C4 hubs.
I have a C4 Hub that has the same problems as @TechMedX and thinking of changing everything to the C-5. Last evening I had to restart the hub numerous times before it came online. @bertabcd1234 You were saying that I can back up the hub database to the new hub?? Did I read that correctly?
If you purchase a Y cable you can move the stick on the C4 over to the C5 and restore from a backup yes..
edit: I need to preface this with the statement that other fairly trusted/experienced forum members have said you can do this. I have never done it myself yet.
Once you move your stick from the C-4 to the C-5 and back up? Do I have to continue using the stick or can I remove it and use the internal Z-Wave and Zigbee Radio's?
The devices are stored on the stick so you need to move that over as well. You can always buy another Nortek stick or use the C4 as a controller type hub like I do...
Clarification: In my situation I have 2 C4's in production and a C5 with radios turned off and being used as a "controller" hub - cloud apps, global stuff etc.
If you own a C4 I recommend you get a Y cable anyway. I bought 2 recently after I discovered that you could do this with the C5.
Curious, why are you moving to C5?
HE staff says they're the same but I'm fairly certain, having opened up both about 8 months ago, and googling the chip numbers, the one on the C4 was more "beefy"
I’m not certain we can just look to the hub on this one. C5 hubs came out at around the same time as Lowe’s closed down Iris and it has been the hub available for migrating Wink users. Few came over prior to the release of the C-5.
Don’t get me wrong, I’m not blaming these users, but the nature of the systems they were used to left them in the dark about a lot of the techniques, procedures and experience that many who came on board from SmartThings at the time of the C-3 and C-4 hubs already possessed.
I’ve also noticed that many in this thread and on the forum that have multiple C-5 hub with no issues, are also more experienced with the technical knowledge and finesse you sometimes need to get a ton of Z-Wave and Zigbee devices to play nice together.
