I am trying to use Leviton DZPD3. That part number does not show up as support. What setting should I use. My Levitons come up at 10% and I can't make them brighter
What driver are you using? It should be generic z-wave dimmer. (It's not z-wave plus)
Leviton seem to have issues sometimes. There are apparently firmware updates for these devices that may help. What firmware is this device on? I think 1.22 is the latest for this device. https://hubconnecteddecorasmart.leviton.com/hc/en-us/articles/4407521680155-Can-Leviton-Z-Wave-Products-Firmware-Be-Updated-
This thread discusses how to update, Leviton DZ6HD and DZ15S firmware upgrades I am not sure they talk specifically about your device, but the process is similar. There is a link within that thread to the OTA update files in post #9.
@dennypage has a lot of experience with Leviton, maybe he can chime in here.
Thanks....
All 4 of these are behaving the same way. They will not get any brighter than 10%. That's the only issue???
It does not seem to be a firmware issue, its something wrong with the HE system driver.
I replied to your other post as well, that you should use my custom driver: All my Leviton DZPD3 Dimmers Have Died - #47 by Scottb8888
In fact most of the thread is talking about the 10% issue and the solution everyone said worked was to use the driver I created.
Great News... How do I get this driver and how do I install it. I am a newbie to Hubitat
Check this doc:
https://docs2.hubitat.com/how-to/install-custom-drivers
Use the Import code option. In my post I have the "Direct Import" link at the bottom. Just right click and copy that link, then paste it into the import code box on the driver creation screen.
Ignore the part of the doc about creating a new virtual device, you already have the device created, but it does now how to set the driver on a device down below.
