That could be it. The driver code is below. Have been messing with this for hours. Appreciate the extra set of eyes.
metadata {
definition (name: "Natty - Z-Wave Garage Door Sensor Button", namespace: "Natty", author: "Chris LeBlanc") {
capability "Garage Door Control"
capability "Contact Sensor"
capability "Actuator"
capability "Sensor"
capability "Battery"
capability "Door Control"
capability "Switch"
capability "Refresh"
capability "Temperature Measurement"
attribute "status", "string"
attribute "buttonPress", "string"
command "actuate"
tiles {
standardTile("status", "device.status", width: 2, height: 2) {
state("open", label:'${name}', icon:"st.doors.garage.garage-open", action: "actuate", backgroundColor:"#ffa81e", nextState:"closing")
state("closed", label:'${name}', icon:"st.doors.garage.garage-closed", action: "actuate", backgroundColor:"#ffffff", nextState:"opening")
state("opening", label:'${name}', icon:"st.doors.garage.garage-opening", backgroundColor:"#ffe71e")
state("closing", label:'${name}', icon:"st.doors.garage.garage-closing", backgroundColor:"#ffe71e")
standardTile("contact", "device.contact") {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label:'${currentValue}% battery', unit:""
main(["status","contact", "acceleration"])
details(["status","contact", "acceleration"])
def result = null
if (description.startsWith("Err 106")) {
if (state.sec) {
log.debug description
} else {
result = createEvent(
descriptionText: "This sensor failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
isStateChange: true,
} else if (description != "updated") {
def cmd = zwave.parse(description, [0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "parsed '$description' to $result"
return result
def updated() {
def cmds = []
if (!state.MSR) {
cmds = [
zwave.manufacturerSpecificV2.manufacturerSpecificGet().format(),
"delay 1200",
zwave.wakeUpV1.wakeUpNoMoreInformation().format()
} else if (!state.lastbat) {
cmds = []
} else {
cmds = [zwave.wakeUpV1.wakeUpNoMoreInformation().format()]
response(cmds)
def configure() {
delayBetween([
batteryGetCommand()
], 6000)
def sensorValueEvent(value) {
def results = []
if (value) {
results << createEvent(name: "contact", value: "open", descriptionText: "$device.displayName sensor is open")
results << createEvent(name: "status", value: "open", unit: "")
results << createEvent(name: "door", value: "open", unit: "")
} else {
results << createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
results << createEvent(name: "status", value: "closed", unit: "")
results << createEvent(name: "door", value: "closed", unit: "")
results
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd)
def result = []
if (cmd.notificationType == 0x06 && cmd.event == 0x16) {
result << sensorValueEvent(1)
} else if (cmd.notificationType == 0x06 && cmd.event == 0x17) {
result << sensorValueEvent(0)
} else if (cmd.notificationType == 0x07) {
if (cmd.v1AlarmType == 0x07) { // special case for nonstandard messages from Monoprice door/window sensors
result << sensorValueEvent(cmd.v1AlarmLevel)
} else if (cmd.event == 0x01 || cmd.event == 0x02) {
} else if (cmd.event == 0x03) {
result << createEvent(descriptionText: "$device.displayName covering was removed", isStateChange: true)
result << response(zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId))
if(!state.MSR) result << response(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
} else if (cmd.event == 0x07) {
result << createEvent(name: "motion", value: "active", descriptionText:"$device.displayName detected motion")
} else if (cmd.notificationType) {
def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, displayed: false)
result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
def cmds = []
if (!state.MSR) {
cmds << zwave.wakeUpV1.wakeUpIntervalSet(seconds:4*3600, nodeid:zwaveHubNodeId).format()
cmds << zwave.manufacturerSpecificV2.manufacturerSpecificGet().format()
cmds << "delay 1200"
if (!state.lastbat || now() - state.lastbat > 53*60*60*1000) {
cmds << batteryGetCommand()
} else {
cmds << zwave.wakeUpV1.wakeUpNoMoreInformation().format()
[event, response(cmds)]
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = now()
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
if (msr == "011A-0601-0901") { // Enerwave motion doesn't always get the associationSet that the hub sends on join
result << response(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
} else if (!device.currentState("battery")) {
if (msr == "0086-0102-0059") {
result << response(zwave.securityV1.securityMessageEncapsulation().encapsulate(zwave.batteryV1.batteryGet()).format())
} else {
result << response(batteryGetCommand())
result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x85: 2, 0x70: 1])
// log.debug "encapsulated: $encapsulatedCommand"
if (encapsulatedCommand) {
state.sec = 1
zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
def batteryGetCommand() {
def cmd = zwave.batteryV1.batteryGet()
if (state.sec) {
cmd = zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd)
cmd.format()
def actuate() {
sendEvent(name: "buttonPress", value: "true", isStateChange: true, unit: "")
def open() {
if (device.currentValue("status") != "open") {
log.debug "Sending button press event to open door"
actuate()
else {
log.debug "Not opening door since it is already open"
def close() {
if (device.currentValue("status") != "closed") {
log.debug "Sending button press event to close door"
actuate()
else {
log.debug "Not closing door since it is already closed"
def on()
open()
def off()
close()
