I just moved the C-8 to a more central location in our home and moved it from WiFi to Ethernet network attachment. The WiFi is now disabled.
The Z-Wave data for signal quality and the like is now not accutate given the new physical location. I would like to reset all of the Z-Wave data so the hub can start the new routings from scratch. I would like to avoid reinstalling the 20+ devices that are associated with the hub.
This seems like something that should be straight-forward to accomplish. Is it possible?
Leaving that aside, are all your devices working and reporting back to the hub? If they are, then I suggest just leaving things alone and the z-wave mesh will sort itself out in a short time.
You can aid the process of the mesh sorting itself out by running a z-wave repair on individual nodes - focusing on those that are not working as well as they used to.
You could also try a z-wave repair on the entire mesh, but I've had mixed results with doing that.
Reboot the hub, that clears all the actual stats out. Does not clear routing info from the devices (even though it may look blank on the hub).
Then you can run a full z-wave repair to kick things off. I would only run that once per 24 hrs.
If you have any problematic devices you can try repairs on just those devices as well.
Everything should sort itself out within 48hrs or so.
