I have a weatherproofed contact sensor, but need ideas to mount it outdoors e.g. on a patio screen door. I don't trust regular adhesive strips to hold in freeze or heat. But I also don't want to glue it with a permanent bond because I may want to replace it in the future. Thoughts?
Most contact sensors have screw holes
Mine doesn't...
Well.. That does make it harder.. Interesting, every one I have tested have holes..
Silicone. Thats what i do. Little bead of white around the sensor, it blends and holds forever.
I've used silicone caulk for this purpose. It can withstand the elements, yet be removed with caulk remover and/or a putty knife at a later point of time. The only thing is that it takes time to set, so you have to tape the sensor in place for an hour or two.
Edit: Ha - @waffles beat me to it!
Upon further examination, it does have placeholders to drill the holes in plastic....but also where I want to mount it is a metal surface, and I'm not keen drilling metal....
Beat ya by about 9 seconds
Does it bond between plastic and metal also?
For sure. I have a metal screen door outside using an entry sensor. It wont come off until i say so. Silicone is pretty strong, ans like @aaiyar said, it can be removed
I mount all my sensors as shown in this thread. Works great.
Hope that does work for contact sensors with a magnetic reed switch?
Scotch 1"x48'' Indoor/Outdoor Extreme Double-Sided Mounting Tape : Target
I used this thing for outdoor, I didn't use it for heavy objects (like mailbox in pictures), just solar path lights on brick walls and they're still on the wall after a few So Cal summers.
I'm also using it for contact sensors outdoor (Samsung multipurpose sensors in a waterproof plastic box) on metal fences. The sensors showed 120F+ in summer and they're still stuck there.
I have mounted outdoor wireless thermometers using Velcro Extreme Outdoor. It will eventually degrade, but even in the extremes of weather in Chicago, it lasts for several years.
I use Iris 3320-L contact sensors and place the magnet about midway (actually on top of the QR code) and it works fine for me.
