I can't figure how to do this rule properly. What I am trying to achieve is if any of my daughters are at home, the guest bathroom light doesn't turn for 30min after motion has stopped. If they are all away then turn off the light when no motion.
I have a virtual switch to turns on if any my daughters are home and the virtual switch turns off when they are all away. I used switches incase I want to rename the switch or use it when I have guest.
Guest Bathroom Motion motion active
Dim: Guest bathroom light: 45
IF (VSwitch Nina or Alexa at home(on) is off(F) [FALSE]) THEN
Wait for event: Guest Bathroom Motion motion inactive
Off: Guest bathroom light
IF (VSwitch Nina or Alexa at home(on) is on(T) [TRUE]) THEN
Off: Guest bathroom light --> delayed: 0:01:00
END-IF
The delay is probably your issue. Once a delay is started unless cancellable the light will get turned off after an hour
Try wait for event and stays, if you edit the wait event there is a slider "and stays" turn that on. Also remove the delay from the second IF. Then if the motion goes active the rule gets retriggered and the wait is canceled.
This should be an ELSE-IF, not an IF. Otherwise, you're embedding this IF inside your first one. The editor would also display this as indented further to help show this. If this was a typo in the post maybe share a screenshot of the rule instead?
I don't see any delays in this rule, only "Wait for event: elapsed time," which is similar to a delay but automatically canceled on re-trigger, so that shouldn't be a problem.
Ah yeah, that could do it! Though if how it's written is really as above, I guess that line will never be reached anyway, so not a problem for now. (But something to look at after!)
Thank you. I'm all confused. Could you show me how it should look like?
This is what I have now and it seems to work except it doesn't start the timer over with motion actives again. I do have the cancelable on.
ELSE-IF (VSwitch Nina or Alexa at home(on) is on(T) [TRUE]) THEN
Off: Guest bathroom light --> delayed: 0:01:00(cancelable)
END-IF
A cancelable action has to be cancelled explicitly. So, you would want your first action to be "cancel delayed actions" or, you can do what I wrote below. The wait action is auto-cancelled anytime the rule is re-triggered.
Trigger: Guest Bathroom Motion active
Actions:
Dim: Light: 45
IF (VSwitch is OFF) THEN
Wait for event: Motion inactive
Off: Light
ELSE-IF (VSwitch is ON) THEN
Wait Event: Guest Bathroom motion inactive and stays that way for: 0:01:00
OFF: Light
END-IF
END-IF
You'd actually want something like this for the actions--no extra level of nesting, though the editor wouldn't quite let you do the above anyway:
Off: Light
Off: Light
END-IF
Thinking about this more, you could also just use ELSE instead of ELSE-IF, since a switch can only have two states, and there's no need to explicitly test for the other possibility.
Since Off is common to both scenarios, you could simplify even more.
ELSE
END-IF
Off: Light
Actually, there is no reason to check the value of VSwitch a second time because if it's not OFF then you've already determined that it is ON. Replace the ELSE-IF with an ELSE and remove the "THEN".
On: Guest bathroom light
IF (VSwitch Nina or Alexa at home(off) is off(T) [TRUE]) THEN
ELSE Wait for event: Guest Bathroom Motion motion inactive and stays that way for: 0:30:00
END-IF
IF (VSwitch Nina or Alexa at home is on) Wait for event: duration: 0:30:00
Note that the IF is a simple condition and therefore no THEN or END-IF.
There are many ways to achieve the same results. The most important thing is that whatever rule you use, you understand how it works and can debug if a problem arises later.
