Motion lights / modes when NvidiaShield is in sleep mode only?
Another motion light rule question!
I don't know if this is possible, but I would like to make a rule that only turn on lights based on motion detection if my nvidia shield is in sleep mode ... do you think this is possible?
I currently have an Nvidia shield device in my hub using the plex communicator app .. Not sure if this can help?
Wondering if you ever worked this out.
I'd suggest that you test using the Shield's mode to either set a variable or trigger a virtual switch, and then use the variable or switch as a condition for the rule.
Unfortunatly it doesn't seem to be possible to do this for now. I have started another topic to request a driver for Android TV.
Android TV playback status driver? - Community Apps and Drivers - Hubitat
