I am using the Motion and Mode Lighting app. I noticed that if the light is turned on through any method other than by triggering the motion sensor—for example through a contact sensor, voice prompt, or physical button—unless the motion sensor detected activity the motion rule doesn’t turn the light off.
To be more specific, I have a contact sensor that triggers a rule which turns on my garage lights. It fires a lot quicker than relying on the motion sensor alone, which is the main reason why I use it. Sometimes, the door opens and then closes shortly after, without anyone actually going into the garage. So the motion sensor inside the garage never detected motion. I notice that the lights will turn on, and stay on.
I expected the motion sensor would turn off lights after a certain amount of time passed with no activity. Is there a way to enable this function in the Motion and Mode Lighting app somewhere?
