Thought I would bring this out into a new thread.
I was reading the docs for this app and I have a question about the fade feature. I have a light I would like to ramp up from 0 to 95 in a certain amount of time. Is this possible with the fade? I tried different values for the fade in seconds but it does not seem to change. thanks
Is there anyone who knows if the fade works for up or down? I am trying to get it to fade up but no amount of time seems to do anything. Any help appreciated.. thanks
This all depends on the device. Some dimmers fade and some don't. What kind of dimmer is it? You can test it from the device page.
It is a zooz zen24 and I have had it dimming already by using a rule but with a rule it kept coming back on and wouldn't shut off and stay off. It would also be nice if there was a way to do a delay time like in a rule too. What is the maximum time you can use for the fade? thanks
The current version of ZEN24 only has 2 options for ramp rate - regular (slow, around 2-3 seconds for full up and down) and fast - up/down within a second so that may be a reason why it's not working for you. The next version will feature a full ramp range and you should also be able to update your current dimmers with that new firmware once it's ready. We estimate to have the new production set-up within a month. Feel free to reach out to our support to receive the OTA file and a notification once the new version is out.
Thanks Agnes. I will contact your support and give them an email address.
