Motion Lighting App Bulb not turning on
I have 2 bulbs and only one bulb turns on with a Motion Lighting App, however the log shows it is sending the same commands to both bulbs. A Group was created with the same 2 bulbs, which turns both lights on and off. The bulb that works is a Philips Hue and the one that does not work is a new Sylvania Smart+ PAR38 bulb.
dev:22019-12-09 09:36:17.923 pm infoOutside Front Motion temperature is 38.61°F
dev:442019-12-09 09:31:33.515 pm infoFront Tree Motion temperature is 38.59°F
app:1012019-12-09 09:31:29.863 pm infoOutside Back Left Flood was turned off
app:1012019-12-09 09:31:29.835 pm infoOutside Backdoor Light was turned off
dev:652019-12-09 09:31:29.740 pm infoOutside Back Left Flood was turned off
dev:392019-12-09 09:31:29.687 pm infoOutside Backdoor Light was turned off
app:1012019-12-09 09:31:29.275 pm infoTurning off lights
dev:382019-12-09 09:24:11.474 pm infoOutside Back Motion temperature is 39.20°F
app:1012019-12-09 09:21:29.125 pm infoDelaying off for 10 minutes
app:1012019-12-09 09:21:29.050 pm infoMotion inactive Outside Back Motion
dev:382019-12-09 09:21:28.931 pm infoOutside Back Motion is inactive
dev:22019-12-09 09:21:18.979 pm infoOutside Front Motion temperature is 40.14°F
dev:652019-12-09 09:21:16.734 pm infoOutside Back Left Flood was set to 100%
dev:392019-12-09 09:21:16.704 pm infoOutside Backdoor Light was set to 100%
app:1012019-12-09 09:21:16.661 pm infoOutside Back Left Flood turned on
app:1012019-12-09 09:21:16.636 pm infoOutside Backdoor Light turned on
dev:652019-12-09 09:21:16.530 pm infoOutside Back Left Flood was turned on
dev:392019-12-09 09:21:16.513 pm infoOutside Backdoor Light was turned on
app:1012019-12-09 09:21:14.947 pm infoSetting dimmers [Outside Backdoor Light, Outside Back Left Flood] to 100
app:1012019-12-09 09:21:14.901 pm infoMotion active Outside Back Motion
dev:382019-12-09 09:21:14.868 pm infoOutside Back Motion is active
--- Live Log Started, waiting for events ---
This is likely the problem. :wink: But there are a few things you can try. Take the Motion Lighting app out of the picture for a second: if you turn the group and off yourself (directly from the device page), do both bulbs respond as expected? You should also check that the Sylvania device responds as expected if you again manually manipulate it on and off direclty from its device page (if it doesn't, repairing might help, but it's a Sylvania, so it's possible nothing will help...I'm not sure if you can tell how I feel about these). If the individual device works fine but the group doesn't, sometimes I've had to go into the group app, remove the bulb, add it back, and hit Done, especially if I re-paired it for any reason but sometimes even when setting them up new, before all of them will work. Enabling Zigbee group messaging if you haven't is also likely to help. You can experiment with on/off optimization either way, but I suspect with only two bulbs and group messaging, it's likely to be fine if off.
Something else you might want to be aware of: Zigbee bulbs generally don't play well with non-bulbs, which is a concern if you have other types of Zigbee devices (motion sensors, outlets, etc.) on the same network. The end of Hubitat's Zigbee docs touch on this a bit, but you can find dozens of forum threads here (and elsewhere) documenting the same: https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Zigbee_Mesh#Tips_for_designing_your_Zigbee_mesh
When I turn both lights on and off using the group lighting, they function fine.
I found that if the Motion Lighting App dimmer level is set to a new value (example, set to 99 after it was 100) then the Motion Lighting App turns both bulbs on. However, if the dimmer level remains at the previous value, the next time it is triggered, the SMART+ bulb does not turn on.
I came up with a work around. The "dimmer" was replaced with a "switch" using the "group" (both bulbs). The dimming can be set from within the group or the individual devices.
