app:212019-06-11 10:56:18.501 pm errorjava.lang.NumberFormatException: For input string: "35.0" (overrideOn)
Seeing this new error in my motion lighting rules but so far only on rules that control lutron caseta switches.
Please show such a case.
When are you getting the error? When you create this, or when it runs?
when the mode changed last night to evening. (Sorry was kind of busy last night but at least wanted to grab the error.) So I checked my other ML rules that change dimmers on mode changes....it was only the lutron ones that had this same error.
Is app 21 the Lutron Integration or the ML rule?
how can I find that?
If it's the number that's in the URL for the rule, then it's the ML rule.
OK. Will investigate further.
OK, bug found and fixed. We allowed Caséta 'dimmers' to report decimal values due to an issue that arose with the Caséta Fan Controller. It was being used as a dimmer, and we needed decimal values for selecting the speed due to a firmware bug in the device. That made Caséta dimmers the only ones reporting a decimal value (35.0 in your case), and ML didn't like decimal, expecting integer (35). Every other dimmer reports and expects integer values. Easy enough fix... Next release.
