Motion and Mode App
I have a zooz motion sensor (ZSE11) in my garage and I use to turn the garage light on when it's dark out. I then turn the light off after 5 mins (In case I forget). I do this my controlling the lightswith and its works perfectly.
The issue comes when I want to manually turn the light on. Once I move past the motion. the light turns off 5 mins later.
I need to figure out how to ignore the motion when I turn the light on using the switch and I am not sure how to get this done using the Motion and Mode app. My setup is below.
Anyone have any suggestions?
Thank you
The app has several options that could help, depending on what you exactly want, but a good place to start might be the Don't turn off if already on option.
Well dang.. I glazed right over that..
