Node topology gives you an overview of the entire Z-Wave routing table. Blue dots are nodes that can see each other, and red are nodes that aren't neighbors.
Seeing a bunch of red is not an indication of a bad network.. Especially where battery devices are concerned, because they don't update their neighbors..
The point of this is to give you a quick look at what nodes can "see" what other nodes.. Gives you an idea of how things can route.. It can also be a good tool to decide where to place repeaters.. But with no context of where these nodes are physically and what type of device they are, you can't make a judgment based on this graphic alone..
Here is mine.. You can clearly see the bulk of my battery devices:
