If you have any use of InfluxDB you can also use my "InfluxDB Hubitat Live Logger" Driver. It is based on @staylorx driver and takes the live logging data and puts it in a InfluxDB db so you can use a dashboard to view the data externally. It works really well.
Driver:
raw.githubusercontent.com/Mavrrick/Hubitat-by-Mavrrick/refs/heads/main/InfluxDB_Logger_V2/InfluxDB_Hubitat_Live_Logger
Dashboard json for import:
"__inputs": [
"name": "DS_INFLUXDB_HUBITAT2",
"label": "InfluxDB Hubitat2",
"description": "",
"type": "datasource",
"pluginId": "influxdb",
"pluginName": "InfluxDB"
"__elements": {},
"__requires": [
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "10.4.5"
"id": "influxdb",
"name": "InfluxDB",
"version": "1.0.0"
"type": "panel",
"id": "table",
"name": "Table",
"version": ""
"type": "panel",
"id": "timeseries",
"name": "Time series",
"version": ""
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"uid": "grafana"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"target": {
"limit": 100,
"matchAny": false,
"tags": [],
"type": "dashboard"
"type": "dashboard"
"description": "Telegraf / InfluxDB / Grafana as syslog receiver",
"editable": true,
"fiscalYearStartMonth": 0,
"gnetId": 12433,
"graphTooltip": 0,
"id": null,
"links": [],
"liveNow": false,
"panels": [
"datasource": {
"type": "influxdb",
"uid": "${DS_INFLUXDB_HUBITAT2}"
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisBorderShow": false,
"axisCenteredZero": false,
"axisColorMode": "text",
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "bars",
"fillOpacity": 100,
"gradientMode": "hue",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"insertNulls": false,
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "normal"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 7,
"w": 24,
"x": 0,
"y": 0
"id": 10,
"interval": "",
"options": {
"legend": {
"calcs": [
"mean",
"max",
"sum"
"displayMode": "table",
"placement": "right",
"showLegend": true
"tooltip": {
"mode": "single",
"sort": "none"
"pluginVersion": "10.1.4",
"targets": [
"alias": "Info",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"measurement": "syslog",
"orderByTime": "ASC",
"policy": "default",
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "info"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"value": "/^$hostname$/"
"condition": "AND",
"key": "severity",
"operator": "=~",
"value": "/^$severity$/"
"condition": "AND",
"key": "appname",
"operator": "=~",
"value": "/^$appname$/"
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Notice",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "notice"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Warning",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "D",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "warning"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Error",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "C",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "err"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Critical",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "E",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "crit"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Alert",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "F",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "alert"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"alias": "Debug",
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"1m"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "G",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [],
"type": "count"
"tags": [
"key": "severity",
"operator": "=",
"value": "debug"
"condition": "AND",
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"title": "syslog count",
"type": "timeseries"
"datasource": {
"type": "influxdb",
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"custom": {
"align": "left",
"cellOptions": {
"type": "auto"
"filterable": false,
"inspect": true
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "dark-purple",
"value": null
"color": "dark-red",
"value": 2
"color": "dark-orange",
"value": 3
"color": "dark-yellow",
"value": 4
"color": "rgb(150, 150, 150)",
"value": 5
"color": "rgb(51, 51, 51)",
"value": 6
"color": "rgb(5, 5, 5)",
"value": 7
"overrides": [
"matcher": {
"id": "byName",
"options": "severity_code"
"properties": [
"id": "mappings",
"value": [
"options": {
"0": {
"text": "Emergency"
"1": {
"text": "Alert"
"2": {
"text": "Critical"
"3": {
"text": "Error"
"4": {
"text": "Warning"
"5": {
"text": "Notice"
"6": {
"text": "Info"
"7": {
"text": "Debug"
"type": "value"
"id": "custom.cellOptions",
"value": {
"mode": "gradient",
"type": "color-background"
"id": "custom.width",
"value": 119
"matcher": {
"id": "byName",
"options": "Time"
"properties": [
"value": 163
"matcher": {
"id": "byName",
"options": "hostname"
"properties": [
"value": 194
"matcher": {
"id": "byName",
"options": "appname"
"properties": [
"value": 330
"gridPos": {
"h": 24,
"w": 24,
"x": 0,
"y": 7
"id": 12,
"options": {
"cellHeight": "sm",
"footer": {
"countRows": false,
"fields": "",
"reducer": [
"sum"
"show": false
"showHeader": true,
"sortBy": [
"desc": true,
"displayName": "Time"
"pluginVersion": "10.4.5",
"targets": [
"datasource": {
"type": "influxdb",
"groupBy": [
"params": [
"hostname"
"type": "tag"
"params": [
"appname"
"type": "tag"
"refId": "A",
"resultFormat": "table",
"select": [
"params": [
"severity_code"
"type": "field"
"params": [
"message"
"type": "field"
"tags": [
"key": "hostname",
"operator": "=~",
"condition": "AND",
"key": "appname",
"operator": "=~",
"condition": "AND",
"key": "severity",
"operator": "=~",
"condition": "AND",
"key": "message",
"operator": "=~",
"value": "/$Query/"
"title": "Syslog Messages",
"type": "table"
"refresh": "",
"revision": 1,
"schemaVersion": 39,
"tags": [],
"templating": {
"list": [
"allValue": "",
"current": {},
"datasource": {
"type": "influxdb",
"definition": "SHOW TAG VALUES FROM syslog WITH KEY=appname",
"hide": 0,
"includeAll": true,
"label": "Appname",
"multi": true,
"name": "appname",
"options": [],
"query": "SHOW TAG VALUES FROM syslog WITH KEY=appname",
"refresh": 2,
"regex": "",
"skipUrlSync": false,
"sort": 1,
"tagValuesQuery": "",
"tagsQuery": "",
"type": "query",
"useTags": false
"allValue": "",
"current": {},
"datasource": {
"type": "influxdb",
"definition": "SHOW TAG VALUES FROM syslog WITH KEY=hostname",
"hide": 0,
"includeAll": true,
"label": "Hostname",
"multi": true,
"name": "hostname",
"options": [],
"query": "SHOW TAG VALUES FROM syslog WITH KEY=hostname",
"refresh": 2,
"regex": "",
"sort": 1,
"tagsQuery": "",
"type": "query",
"useTags": false
"allValue": "",
"current": {},
"datasource": {
"type": "influxdb",
"definition": "SHOW TAG VALUES FROM syslog WITH KEY=severity",
"hide": 0,
"includeAll": true,
"label": "Severity",
"multi": true,
"name": "severity",
"options": [],
"query": "SHOW TAG VALUES FROM syslog WITH KEY=severity",
"refresh": 2,
"regex": "",
"sort": 0,
"tagsQuery": "",
"type": "query",
"useTags": false
"current": {
"selected": false,
"text": "",
"value": ""
"description": "Querystring",
"hide": 0,
"label": "MessageQuery",
"name": "Query",
"options": [
"selected": true,
"text": "",
"value": ""
"query": "",
"type": "textbox"
"time": {
"from": "now-1h",
"to": "now"
"timepicker": {
"refresh_intervals": [
"5s",
" 10s",
" 30s",
" 1m",
" 5m"
"time_options": [
"5m",
"15m",
"1h",
"6h",
"12h",
"24h",
"2d",
"7d",
"30d"
"timezone": "",
"title": "Syslog",
"uid": "cbdb07f7-6b6d-46f5-8e6c-4cd9dabf796e",
"version": 2,
"weekStart": ""
