What driver are people using with this? I tried @kkossev 's Tuya Temperature Humidity Illuminance LCD Display with a Clock driver but it doesn't show humidity on this device it seems...
Fingerprint
Fingerprint
Have you tried the HE inbuilt "Generic Zigbee Temperature/Humidity Sensor" ?
It seems like this device uses the standard Zigbee clusters for reporting ...
Update: please copy&paste the fingerprint as a text.... I just can't type in the manufacturer name TUYATEC_zxxyghxgygxx without a typo!
fingerprint profileld."0104*, endpointld:01, inClusters:0000,0001,0003,0402,0405, outClusters:0003,0402,0405*, model:"RH3052*, manufacturer: "TUYATEC-gqhxixyk"
One nice thing about working on an iPad is that since iOS 16, it is possible to copy text from images….
I tried that first but it didn't register it seemed... I'll give it another whirl... It may just be I didn't let it go long enough..
dev:23862023-02-10 03:40:00.164 PMinfoZigbee parsed:[raw:778A010001102000201E210020C8, dni:778A, endpoint:01, cluster:0001, size:10, attrId:0020, encoding:20, command:0A, value:1E, clusterInt:1, attrInt:32, additionalAttrs:[[value:C8, encoding:20, attrId:0021, consumedBytes:4, attrInt:33]]]
dev:23862023-02-10 03:40:00.161 PMinfoZigbee parsed:[raw:778A010000080100204A, dni:778A, endpoint:01, cluster:0000, size:08, attrId:0001, encoding:20, command:0A, value:4A, clusterInt:0, attrInt:1]
dev:23862023-02-10 03:39:57.942 PMinfoZigbee parsed:[raw:778A0104050A000021330E, dni:778A, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:0E33, clusterInt:1029, attrInt:0]
dev:23862023-02-10 03:39:57.936 PMinfoZigbee parsed:[raw:778A0104020A000029C009, dni:778A, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:09C0, clusterInt:1026, attrInt:0]
dev:23862023-02-10 03:39:56.689 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0001,0003,0402,0405", outClusters:"0003,0402,0405", model:"RH3052", manufacturer:"TUYATEC-gqhxixyk"
dev:23862023-02-10 03:39:56.189 PMtraceZCL version:03
dev:23862023-02-10 03:39:56.186 PMtraceSoftware Build Id:unknown
dev:23862023-02-10 03:39:56.185 PMtraceModel:RH3052
dev:23862023-02-10 03:39:56.183 PMtraceManufacturer:TUYATEC-gqhxixyk
dev:23862023-02-10 03:39:55.715 PMdebuggetting info for unknown Zigbee device...
I have three Moe's temp/humidity sensors without the LCD readout that are performing well uusing the Generic Zigbee Temperature/Humidity Sensor driver.
I am using them to automate my bathroom exhaust fans based on humidity rise above the average house level.
I also have one of the devices with the LCD display. It did not work with the generic driver, but works with the custom Tuya Temperature Humidity Illuminance LCD Display driver.
Hi Rick, It's simple just copy paste the above into @kkossev's driver in the fingerprint section. It will likely work, can't hurt to try
EDIT-The outclusters seem unique, waiting for Krassimir to evaluate
Well the moes is reporting now with the Generic Zigbee Temp/Humidty sensor driver. I guess I was being impatient on waiting for it....
@mike.maxwell It pairs as DEVICE can you add the fingerprint to HE?
Do you get a battery level report on these? I am getting consistent temp and humidity reports, but no battery level. I wouldn’t care, but Homekit always shows the battery level as zero, and if I remove passing the battery level to Homekit, it also stops reporting humidity to Homekit for some reason.
Which driver are you using?
@kkossev 's tuya driver
I’ll have to try that again. Thanks
I changed to that driver, reset and rejoined the sensor, and badabing, battery reporting now works.
Good deal!
