Thanks for the response!
Is it just me or if I set up the switch properly, i.e. setting exactly the fully open/close states, then it should know always what position it is in. I also see the variable "position" (see screenshot) which is relatively accurate and changes each time I open/close.
I wonder if anyone worked this out as "position" is a key ingrediant in automating curtains. Otherwise it's just a manual switch.
The 'position' attribute is accurate when the curtain motor reports back the exact position to the hub.
With these Zigbee Curtain Switch modules it is quite possible that Tuya is simulating the position based on a simple timer. With one of my Zemismart motors I see that Smart Life is simply trying to animate the opening/closing process, without knowing the exact position of the motor.
היי גם אני גר בישראל ותקוע עם אותה בעיה רק שלא ממש הבנתי מה הם הציעו לך לעשות ממש הודה לך אם אפשר שתסביר לי בטלפון
0504886600
מאיר
