This device has been assigned the Tuya Metering plug driver at some time, what you see in the logs is the plug polling job from the previous driver...
Change the driver temporarily to the HE inbuilt driver 'Device' and click on the 'Delete All Scheduled Jobs' button. Then, return to the driver that works with this switch.
Solo me pasaba con este pero ya está solucionado. Funcionó tras quitar la pila y volverla a poner después de 10 minutos aproximadamente.... Muchas gracias
I've been using these for a quite a while and I love them. However, just recently they started to report two events each time i push the button once. I don't remember this evey being a problem before, but its quite regular now. Anyone else experience this? The following events got triggered from a single push. both events happend within 1 sec of each other. Using the Tuya Scene Switch TS004F driver.
@kkossev , my switches are reporting as model "TS0044" and are sending double pressed events. I added to the debounce list and it seems to have stopped triggering to button presses. I put together a PR for you.
Hi, I'm currently facing the same issue as well where my Moes 4 button scene switch is sending single press trigger events twice within a second of each other. Did you manage to solve the issue?
