I'm using Mode Manager to manage simple modes based solely on the time of day. But for some reason, it has started ignoring the change.
Mode Manager showing "Evening" even though it should be "KidsSleep" since its after 730pm.
With something this simple, I don't know where to begin to sort this out. I can change the mode manually, but that defeats the purpose of all this.
Any ideas?
Simple stuff;
Is the time zone correct on the hub?
And the time is correct?
JNS
4
I think I read somewhere that Bruce had someone change their timezone and then change it back when they had a similar problem.
I'll give that a shot.
I was looking through the event log, and it just skipped right over the change.
JNS
6
I can't find the post. I don't recall if they had to reboot the hub between changes. Other than that I don't know what to tell you.
You don't need to find it. I believe you and am more than willing to give it a shot.
Thanks for the tip!
