I only use 4 Modes.
Day, Evening, Sleep Time, and Away
I tried removing all that did not apply but it returned a Null Value. How do I remove this?
I only use 4 Modes.
Go to Settings / Modes. You should be able to delete it there.
If you can't resolve this, send me a PM and I can help you...
I have the same issue except with 4 NULL Modes. Is there a documented way to get rid of these? How does this happen? Would like to know what I did to cause this.
thanks in advance.
There is a way to fix Mode Manager, and if you send me a PM I could guide you through it. But, a simpler way is to just remove Mode Manager and start over.
To remove it, first look at its UR, like this:
http://192.168.0.66/installedapp/configure/31585/mainPage
Except with your hub IP and some other number instead of 31585. Then open this page:
http://192.168.0.66/installedapp/status/31585
Again with your IP and app ID number. At the bottom of that page you can remove Mode Manager.
Dang, Bruce. That is the biggest app number I have seen. Is there some limit you might hit, or does it reuse old numbers (or are they random?)
I install a lot of apps...
Thanks Bruce. This worked fine.
When it gets high enough the hub. will evolve and become sentient.
Did you have modes that you deleted? (Morning, Day, etc.)
Yes. I am new withe Hubitat so I was playing around with Modes in attempt to better understand how I can use them. So, I created and then deleted several experimental modes.
I suspect that is where the nulls came from. Glad you were able to get it sorted.
I have this to. I see the way to fix is just remove mode manager and then put it back. Is that all. I dont have to do anything with apps or rules using these modes before removing it? Just want to be sure its that simple and wont cause a problem before I proceed. @bravenel
Yeah, you can just remove it and redo. The null mode is harmless though.
There will be a fix for this issue in the next release also.
I read that. Since it wont cause a problem will it go away just by updating if I wait for it?
Yes.
