Has this worked in the past on Saturday? Is this a new failure?
Settings
Name | Type | Value |
atSunsetOffset21Evening | number | -30 |
atSunsetOffset22Evening | number | -30 |
atTime11Day | time | 09:00 |
atTime11Evening | time | 18:00 |
atTime11Night | time | 01:30 |
atTime12Evening | time | 18:30 |
atTime21Morning | time | 05:30 |
atTime22Morning | time | 07:00 |
daily | bool | true |
days1Day | enum | ["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"] |
days1Evening | enum | ["Monday","Tuesday","Wednesday","Thursday","Friday"] |
days1Morning | enum | ["Monday","Tuesday","Wednesday","Thursday","Friday"] |
days1Movie | enum | ["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"] |
days1Night | enum | ["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"] |
days2Evening | enum | ["Sunday","Saturday"] |
days2Morning | enum | ["Sunday","Saturday"] |
ignoreModes | enum | ["Away","Movie"] |
logging | bool | true |
returnSensors | capability.presenceSensor | [K Phone], [J Phone] |
time11Day | enum | A specific time |
time11Evening | enum | A specific time |
time11Morning | enum | Sunrise |
time11Night | enum | A specific time |
time12Evening | enum | A specific time |
time12Morning | enum | Sunrise |
time21Evening | enum | Sunset |
time21Morning | enum | A specific time |
time22Evening | enum | Sunset |
time22Morning | enum | A specific time |
type1Day | enum | Certain time |
type1Evening | enum | Earlier of two times |
type1Morning | enum | Earlier of two times |
type1Movie | enum | Certain time |
type1Night | enum | Certain time |
type2Evening | enum | Earlier of two times |
type2Morning | enum | Earlier of two times |
useTimes | bool | false |
Event Subscriptions
Source | Event | Handler | Filter |
Home (Location) | sunsetTime | beforeSunsetHandlerNew | false |
Home (Location) | sunrise | sunriseHandlerNew | false |
Home (Location) | mode | modeHandler | false |
Application State
Name | Value |
shadowMode | Day |
str | Day: at 09:00 on Sun, Mon, Tue, Wed, Thu, Fri, Sat Evening: Earlier of two times, 18:00 or Sunset -30 minutes on Mon, Tue, Wed, Thu, Fri Evening: Earlier of two times, 18:30 or Sunset -30 minutes on Sun, Sat Morning: Earlier of two times, Sunrise or 05:30 on Mon, Tue, Wed, Thu, Fri Morning: Earlier of two times, Sunrise or 07:00 on Sun, Sat Night: at 01:30 on Sun, Mon, Tue, Wed, Thu, Fri, Sat Modes to ignore time changes: Away, Movie |
strP | |
strS | |
timeVarUpdate | true |
updated | true |
updateIgnore | true |
Scheduled Jobs
Handler | Next Run Time | Prev Run Time | Status | Schedule |
timeHandlerNew | 2022-05-07 18:30:00 EDT | 2022-05-06 18:30:00 EDT | PENDING | 0 30 18 * * ? |
timeHandlerNew | 2022-05-07 19:43:00 EDT | PENDING | Once | |
timeHandlerNew | 2022-05-08 05:30:00 EDT | 2022-05-07 05:30:00 EDT | PENDING | 0 30 5 * * ? |
timeHandlerNew | 2022-05-08 01:30:00 EDT | 2022-05-07 01:30:00 EDT | PENDING | 0 30 1 * * ? |
timeHandlerNew | 2022-05-08 07:00:00 EDT | 2022-05-07 07:00:00 EDT | PENDING | 0 0 7 * * ? |
timeHandlerNew | 2022-05-07 18:00:00 EDT | 2022-05-06 18:00:00 EDT | PENDING | 0 0 18 * * ? |
timeHandlerNew | 2022-05-08 09:00:00 EDT | 2022-05-07 09:00:00 EDT | PENDING | 0 0 9 * * ? |
The publish schedule in the original post has been in place since 2020. THe new failure on the sunrise on weekends started recently, perhaps several weeks ago. I am not positive when it failed as we typically wakeup before sunrise / 7am trigger and morning mode is triggered manually.
So in summary i am not positive when it began to fail, but i first noticed in the last three weeks.
Please see the private message I just sent to you.
Hi guys,
Am I the only one having problems with Modes???
Yesterday I noticed that some devices started acting weird, without a logical reason, and afer a while I detected that MODE changes is not working.
I´ve gone through all options on MODE MANAGER, but couldn´t notice anything wrong, besides the fact that I havent touched anything on that APP.
Any comments from the Hubitat Team?
Thanks.
Note: I´m on 2.3.2.125, Mode Manager Version 1.1.6 (5/22/2022)
Note 2: This is a copy of another message posted
For the past couple days, my mode manager is not working correctly, either. Specifically, I set the mode to "Day" at sunrise, and after sunrise it has still been set to "Night" mode.
This corresponds with update to v2.3.2.125
Open Logs page, and look at Location Events. See if there is a sunrise event at the right time. Also, be sure logging is on in Mode Manager. There was nothing in 2.3.2.125 that would have caused this.
Can you check if updating to 2.3.2.126 fixes the issue?
I just enabled logging for mode manager (typically have it off)... Hopefully I'll have something in the morning.
Yes, it is working again.
Not sure if this is related but I have not made any changes to my hub in over 6 months other then firmware updates. But recently I noticed that my Evening and Night modes seem to be having issues. The hub will switch from evening to night and then back to evening for some reason.
The issue started with the 2.3.2 series of updates, not sure exactly which one though.
Looks like the Night changes correctly, but there is an issue with the earlier of two times for the Evening mode. It fires at 7:30PM fine, but then after the Night mode changes, it fires the Evening mode again (interesting that it skipped the Evening mode the day before yesterday). There was a bug fix released for this issue with version 2.3.2.125. Be sure your hub is running the latest version. If it does, open the Mode Manager app, make a small change then (E.G set the Evening mode second time to Sunset + 25 instead of 30) then click done, and done to save the change. That way your schedules will be recreated.
Thanks, changing the offset to a different value and saving solved the issue.
@bravenel @bobbyD I've got a different problem.
Mode Manager is changing to Day/Night at Sunrise/Sunset, but it's not ignoring it when set to Away, so as I'm actually Away this means it's disarming HSM every day at Sunrise / Sunset!
Not exactly useful, as everything triggers off Mode changes!
It's a C7 running 2.3.2.134.
It appears to suffer from the Sunrise setting, as again this morning I got the switch from Away to Day, so it's every day, not a one off.
Presence sensor and phone are Away and haven't changed state.
I checked the logs and it just says Shadow mode set to Day which then triggers HSM to disarm.
Remove this copy of it, and create it fresh. See if that fixes the problem. This is an odd thing, and no one else is reporting it, and the app is used a lot.
Removing seems to have fixed it, so thanks.
