Ok so I think there is something funky going on with mode manager and Configure daily settings (CDS) .... just removed and added back in MM and did not set CDS and things look good again ... as in the scheduled jobs are there and right.....
Could it be that when you setup a routine with CDS off then activate CDS ... things go sideways ..... Iāll test over the next week or so and see
Ps hub is running the most current release of the code base
I have periodic issues with MM not changing. I've sorted it out in the past by removing the app, and then putting it back, but it's frustrating that this keeps happening.
I had to delete and reinstall the app a while back; no trouble since, but no big changes either. Sometimes I feel like every time something is changed, there is a chance for data corruption. Of course there is, but I never expected it to be very highly likely, which it has often seemed. That is why I try not to ever make changes anymore, just delete an app, rule, group, whatever and start over.
For no apparent reason, Mode Manager stopped working for me as well (partially). It still changes to Daytime at 6am. IFFT is able to change it to Away based on us leaving our WiFi through Fing. It also changes back to Home. What it won't do is to switch to Home Evening at Sunset -30. I tried changing to just sunset (without offset), and it won't do that either. I've tried rebooting the hub 2-3 times, to no avail. Sunset is accurately displayed in the location and mode tab of Settings. Not sure what to try to correct this, since it's been flawlessly changing for several years. It stopped a week ago, and I don't believe I've done a firmware update since then. I'm on the latest (2.2.1.116)
Mode Manager has not worked for the last 3 weeks. Very disappointing!!!! I think that they (Hubitat) may not care or even know how to resolve this problem.
What have you done to troubleshoot? Have you submitted a support request? The Hubitat team cannot possibly read every thread on this board, so they might not know there is an issue. Or it might be isolated to just something on your system.
The community can try to help if you wish. Maybe start by posting your settings and/or system logs in a screenshot.
Have you tried deleting and reinstalling MM? Itās merely an app to change modes, so it shouldnāt upset anything else. I had this problem once early on and havenāt since reinstalling it.
Iāve had to delete it twice in the last 4 months I think. It just seems to stop working, but itās simple enough to reinstall it. Didnāt affect anything else.
I have also just started having this problem, I suspect we have different names for the mode (night). I have / had it set to sunset and for some reason it wonāt switch after returning from away.
At the suggestion of others who posted here, I deleted the Mode Manager app, then reinstalled, and itās been working ever since then. Not sure why thatās become necessary, and hopefully, wonāt need to do it very often, but at least we know the āwork-aroundā solves the problem.
After the latest updates my Mode Manager began to fail to switch modes. I was even having trouble switching by telling google to change modes. After the standard restarts and clicking "Done" in Mode Manager to try and get things setup with change in behavior. I finally noticed that the time was off by more than 6 years. I had it update time from the browser and it all began to work again. Check the time on the Hubitat and make sure it is up to date.
