I have Mode manager app set up to change to Night mode when time is 23:30. Now I bought zigbee button, and I want to set Night mode by this button instead of time. I can set it to the button, no problem. But I can't cancel the time settings. I go to Mode manager - Set mode based on time of day - Set Night mode based on - it is set up as "certain time". I clik here, change it to "no selection", and it immediatelly switches back to "certain time". How can I stop it from changing this mode based on time?
Can you remove the mode manager?
You have to deselect the time by clearing each field in the time setting. It will still say "certain time". But if the numbers are removed, then it won't have a setting for Night mode anymore.
Thank you bravenel, that works, so I'm sorted. However, it's still kinda workaround, would be great if this can be fixed in some future version, and users can just select "no selection" to disable time settings for mode. Thanks again
Well, now it's clear it's not sorted. Mode changed to Night at the time that was previously set, even when now the time fields are empty.
Did you hit Done? Please show the App Status page (gear icon).
Yes I did press Done. Looking at status page, there still was scheduled job for Night mode. I went to the app, press Done again, and now the scheduled job is gone, so it's probably ok now.
