This is a bug report about Mode Manager.
Scenario:
- I set up the time trigger switch to Night mode at a certain time. That worked.
- After working with it for a while, we decided not to do this and instead start Night mode by a switch instead... however we can't disable the time trigger.
once you enter you can never leave
Here's how it is today:
If I click the selection and then select No selection....
It returns right back to the previous screen with no change. Hm... maybe it does this because a time is set? So I click on the time window:
And try to select No Selection here...
And the same thing happens, it returns to the screen as if I hadn't made a change.
Only workaround we've found: set it one minute before Day starts....
