However, I used to have Friday & Saturday change to Night mode @ 10 pm (and the other days @ 9 pm) - As you can see, all days are now 11 pm (as we usually trigger Night mode manually with Alexa).
Annoyingly, the old 10 pm trigger is still active (has been doing this for 2 weeks now) on Friday/Saturday.
I've tried reconfiguring this multiple times and it's still doing it - the only thing I haven't tried is deleting and re-installing MM.
Its been a while since I had same, but if you enable the time option, enable different time for different days you will probably see the old 10pm, you need to clear those then select same time for every day.
Basically it holds onto the settings unless you clear them
It has been a while since I've messed with MM so the instructions are from memory
True, however it's not a huge deal for me atm so I'm leaving it as is for now so if support want to get to the bottom of the bug on my system they can.
There could be a bug in Mode Manager, not sure. Support won't look into it in your hub. I will take a look at the code for deselecting a time. Usually, a nuisance like this is easily remedied by the aforementioned approach.
