I’m running iOS mobile app version 1.0.8. I’m not at hone to using cloud connected. And the app doesn’t run. When I launch it, just get stuck with the spinner and can select any of the buttons like geofence. And then it crashes.
Looks like local, the app is working.
Are you saying the problem has resolved itself?
I’m saying the app doesn’t crash when on local connection. Not sure about cloud connection
If you disable wifi it should use the cloud dashboard links. Can you verify if that case is where it crash? If so can you check if reselecting the Hub from settings fix it?
Thanks, it’s working again. Not sure what was going on.
