I just purchase a zwave controled power strip that functions as a repeater
everything else I have is Zwave Plus
on a scale of 1 being kill it with fire and 10 being best thing ever how bad is it to add this to my network it will be the only Zwave device and as far from my hub as possible.
Distance doesn't make a difference. The devices choose how they want to route, it could be anywhere in the network.
Generally speaking, you will have a better experience with Zwave plus. For one thing, it can report when it is switched on and off, non-plus usually does not. Speed is slower, range is less.
And why would you buy an out of date protocol when everyone else is trying to dump these old things?
The Zooz power strip has 5 controlled outlets and 2 monitored but not controlled USB outlets. It costs a bit more than the one you were looking at on Amazon. It goes on sale frequently but doesn’t seem to be right now. I want one but do not have one yet. I do have a ton of other Zooz items and they work really well. It’s also Z wave plus and has power reporting and remembers On/Off state after power loss. Check out The smartest house for all the Zooz stuff.
Hay!
What.
Did.
I.
Say?
What did it say?
Did I not personally tell you to stick with Z-wave plus? @pat.richards .. I'm crushed. You didn't believe me? snif
I did that w/ a similar Pinlo power strip and then used the HTTP Get driver for each button so the power strip is 4 separate devices.
If you install the latest Tasmota 8.3, the power button on the device will support multi-taps so physically pressing once toggles button 1, physically pressing twice toggles button 2, etc.
