I paused a rule and delayed the rule to resume after 2 min however the rule that I want to resume This Rule is missing
This is by design, not a bug. A paused rule will not be able to execute to un-pause itself. It must be resumed from another rule (or manually).
Im looking to run a rule for 1 min stop for 2 min run for 1 min stop for 2 and so on.. is there away to do this ?
You can pause and resume this rule from another rule for sure, using whatever schedule or whatnot that you want. Otherwise, if you share more information about the actual automation goal, someone might be able to figure out a different approach that would also work.
