I set up some new Zigbee contact sensors and though they report the temperature in the device settings its missing from the tile on the dashboard. An older sensor shows it just fine but if I make a new tile and select the old sensor it is also missing the temperature on the tile. Is there something I'm missing or was this an intentional change?
Will do. I've also noticed that any contact sensor I now share with the Alexa integration is being treated as a temp sensor (in the alexa app) and not working as a contact sensor any more.
Instead of using Contact Sensor as the template I needed to use Multi Sensor
