Missing some simple trigger events after Upgrade from 2.3.5.152 to 2.3.6.136
I noticed some apps not running after I upgraded from 2.3.5.152 to 2.3.6.136. Their trigger events are very simple. One trigger is simply looking for a boolean variable to change. The trigger variable is changing but the app does not run. I know it is not running because I turned logging on and see no activity. The apps had been running for over a year until the upgrade to 2.3.6.136. I really don't need to used the latest release, I just thought I would try to keep my c-5 hub up to date.
Build 136 is pretty old at this point. Update to 2.3.6.144, the latest as of my writing, and see if the problem persists.
As of 2.3.6.139 your main issue was fixed
  • Rule 5.1:
    • Fixed check for variable changed triggers.
    • Fixed test for triggers relative to a device.
Thanks guys. I will know later this evening, but I am betting the upgrade fixes my problem.
