I created a rule with a smartthings multisensory. It was to notify me if the temp went above or below a temperature. It kept sending me alerts even though the temp was not above or below the set number. I disabled the rule until I could figure out what was going on. But now, even disabled, I still get alerts. Thoughts?
If you look at the device, it will show you what else is acting on it. Maybe something will become evident if you look at that? Otherwise, can you post some shots of your logs and the disabled rule? it would help.
