I know about the Mirror app, which works great but not for what I'm trying to achieve I guess. I'm wondering if there is a way to get it done with RM.
This is the scenario.
Family room has two lights:
- Fan lights (controlled by an Inovelli LZW36).
- Floor lamp (controlled by a Honeywell z-wave outlet dimmer).
The idea is that every time someone taps on the light switch (LZW36), the z-wave outlet should mirror it. Basically the switch should always control (on/off/dim) both lights.
When using voice command and pico remotes I should be able to controll the lights individually. Reason: I may trigger a scene where I do want the fan light to be on and the lamp off, another scene may have different dim levels for both. Also, in my pico remotes I will have different buttons for each one of them meaning I may turn on the fan light only.
Any ideas?
