Using my old hub for a homekit setup. I set up hub mesh with a couple devices from the new hub which I want to use in the homekit. But apparently you can't use mesh devices in Homekit integration.
So I created a virtual switch in the old hub. So if that switch is turned on I want the mesh switch from the other hub to turn on, and vice versa.
Never having used the Mirror app, if I create 2 mirrors, one for each direction will that cause any kind of problems?
I have the HomeKit set up on my main hub. I am using the second hub HomeKit to create a separate home on Apple that has different devices. Reason for this is to share that with someone that only needs, or should only have, part of the devices.
