Mira stopped working?
Has anyone else's Smart Things Mira integration stopped working?
My last successful event from Hubitat to Mira was at 2am on 3/18.
I have rebooted both hubs, which has always cleared up issues in the past.
It appears that events from ST to Hubitat are still working, but Hubitat to ST is not.
Any luck getting it going?
Had to remove the mira driver, delete the device and add it all over again
So you had to delete the driver from Hubitat or Smarthings or both?
Both.
Thanks tried it same problem.
Hy!
I also have a problem with Mira integration. I deleted both drivers, but Mira still doesn't work properly after reinstalling.
Is there a solution?
I did the same as you with no sucess at this point. I moved everything over to Hubithings only one item im having a hard time with is moving my fan and setting the rules to have it working properly
The mira developer hangs out on the Smartthings community forum and responds there. There's a long mira thread you can post questions to. When I posted my issue he said I was the only one who ever had that problem, which isn't quite true as a number of people on Reddit seemed to have the issue as well. It would be good to add your issue to the mix.
