Minoston z-wave mini plug mp31z
It is probably the older 500 chip ZSE40. I dont think the 700 series model can pair in S0 at all.
If it has the 32.x firmware, it can be updated to the latest version 32.12 which eliminates the motion alert every 7 seconds during active motion. There is also a setting on my custom driver that will make it only send ONE alert per event, vs the default of sending two different types of events. [DRIVER] Zooz Sensors Advanced (ZSE40, ZSE41, ZSE42, ZSE44)
Here is the info from my driver post:
NOTE: The ZSE40 v2 with 500 chip has a final firmware update to 32.12 that you can get from Zooz. This sends alerts to the hub at the start and end of active motion only. The repeated alerts every 8 seconds was removed. This will greatly cut down on excessive z-wave traffic.
NOTE: For the original ZSE40 (500 series) FW < 32.12 I would HIGHLY recommend changing Parameter 8 to "Notification Reports Only". For the ZSE40-700 I am myself leaving it at the default to make sure no motion reports get missed.
You also had me curious so I looked up what the PER actually is, Packet Error Rate. Never knew that. I usually look at the custom app that gives the Z-wave details, that shows the error count, or maybe it is the PER and labeled wrong, I will have to pay closer attention to it after my stats build up again after just rebooting.
@jim6 How long since the last reboot when you took that screenshot? Those stats reset every reboot, so that is critical to know.
