Migration from C7 to C8 Pro Zwave not working
I migrated and the Zwave Devices are not working. When I go to Zwave Details nothing is showing and will not work.
I followed all the steps and checked all the boxes under migrate hub. I have hub protect I used for this.
I soft reset and hard reset the new hub and still Zwave will not pickup.
I have done this exercise both cloud and local to try and troubleshoot and still same results.
Any suggestions?
Please check out this thread and see if that solution works for you too.
What's that mean?? The first fix to this type of phenomenon is to power cycle the Hub. Settings: Shutdown, wait for red LED and then remove power for 10 seconds.
I hope that's what YOU mean by "hard reset" :slight_smile:
That worked perfectly. THANK YOU!!
