Internal error occurred while restoring backup.
I've tried multiple cloud backups from my C7 to my new C8 Pro hub. The first one restored but without Z-Wave and Zigbee radio information being included though it said it was. Full reset and no other cloud restore works. Booted the old hub with the new hub off, backed up 3 times now. Same result. Boot the new hub with the old hub off, try to restore the cloud backup that indicates it has radio info but fails. So awesome to spend $100+ on a new hub for it not to work in it's own atmosphere. For what it's worth, I recently switched to ZWave-JS is that the problem?
What version of the firmware are you on?
cc: @bcopeland
It doesn't show the version at the Get Started page.
After login, I can say that both hubs are at 2.5.2.139.
It took the initial import but no radio data apparently. I factory reset and it hasn't taken anything since even after performing multiple cloud backup attempts on the old hub and restore attempts on the new hub.
If you factory reset it, you'll need to re-register it before attempting a migrate.
On the old hub. Have you tried performing a soft reset or a reboot with the advanced option to rebuild the database.
I've tried the soft reset. After it came back up, I restored my local backup and let it sit idle for a bit. I then created a new cloud backup for migration, shut it down, booted the C8 Pro and attempted to restore the cloud backup. It thinks for a minute and then fails everything. I've tried factory resetting it from the Advanced menu in the Diagnostics page as well.
It restored the cloud backup the very first attempt but didn't have any radio information. Every factory reset and attempt after that time is producing this behavior where it fails everything after a minute. I never see a progress bar or anything else.
You may want to check with @support_team to see if they can look at the new hubs engineering logs.
It shouldn't be this hard.
I wonder if there are pending tasks after a reboot of it when you are trying to reset. Maybe go into the diag menu and reset the radios with reboots. Then perform a factory reset with a reboot. Then after a few min another reboot just to ensure nothing is pending. Then try the restore.
Persistence pays off. ZWave-JS is pretty new in Hubitat. I recently switched to that on my C7. I tried switching back to "Legacy ZWave", took a new cloud backup and my C7 cloud backup imported into my C8 Pro hub and shows devices now! Got it sorted! Issue resolved!
That is the same issue I just had with a C7 to C8 migration. I had to set both sides to legacy to get a successful migration.
For anyone doing a migration, keep the ZWave in legacy.
