@support_team Horrific migration from C-7 to C-8 Pro. Purchased (useless) Cloud Backup and Local Backup. Both fail to restore to new hub. Added bonus? Old hub will not exclude ANY devices successfully. I can force, but how to I get devices back to pairing if I force from hub?
Maybe Google how each of your devices has to be factory reset? Or use the C-8 pro to exclude them as unknown devices? Both will work.
I also keep a third party hand held zwave controller around just to exclude devices.
Didn't even need to purchase it for just migration.. As cloud migration is free.
If you don't mind sharing your hub ID over a PM, I can look at the logs and likely fix the issue you are having..
What is exact handheld device, I cannot find one. Of course I spend SIX hours googling how to fix all of this. C-8 Pro is not seeing devices because they are paired to C-7. The C-7 will NOT exclude any device, so the C-8 Pro can never see them. Manual reset on some Eaton Dimmers does not work (not a hubitat problem per se BUT because I cannot exclude it is a Hubitat issue).
Well the cloud "free" migration or Paid Migration both fail
You are apparently unaware that a controller doesn't have to be paired to a device to exclude it. So your C-8 Pro can exclude devices paired to your C-7. Just as my handheld controller (I use a Aeotec minimote) can exclude devices paired to any z-wave controller.
In ALL instances, a device has to be placed in exclusion/inclusion mode to be excluded by a controller. This is not a hubitat requirement; it is a z-wave requirement.
Did you PM your hub ID to @bcopeland as requested?
He did.. And it's related to a bug that was discovered yesterday.. Fix is coming..
I would suggest not messing around with the old hub too much until you migrate.
If you start deleting devices on the old hub, and want to migrate in the future, you won't have a complete migration with all devices as you do at this point.
[hub ID removed by moderator]
new hub
reboot rebuild db then reboot did NOT fix it
Agreed. Was trying anything to get new one working, I bought dupe C-7, C-8, and C-8 Pro, Cloud Backup, Local Backup, etc. Nothing worked.
Hubitat
- Home
- Rooms
- Dashboards
- Devices
- Apps
- Integrations
- Automations
- SubscriptionsFree trial
- Settings
- Logs
- Resources
- Documentation
- Community
- Videos
- Support
Apps and devices
sys:12026-10-26 8:28:29.959 am
info
Z-Wave inclusion stopped
sys:12026-10-26 8:26:48.769 am
info
Z-Wave inclusion started
sys:12026-10-26 8:26:48.743 am
info
Z-Wave Discovery Running
sys:12026-10-25 9:18:38.701 am
info
sys:12026-10-25 9:17:59.629 am
info
sys:12026-10-25 9:17:59.512 am
info
sys:12026-10-25 9:08:41.355 am
info
sys:12026-10-25 9:07:20.000 am
info
sys:12026-10-25 9:07:19.972 am
info
sys:12026-10-25 9:05:25.146 am
info
sys:12026-10-25 9:03:37.272 am
info
sys:12026-10-25 9:03:37.234 am
info
sys:12026-10-25 8:59:03.503 am
info
sys:12026-10-25 8:57:41.147 am
info
sys:12026-10-25 8:57:41.117 am
info
sys:12026-10-25 8:29:07.170 am
info
sys:12026-10-25 8:28:27.644 am
info
sys:12026-10-25 8:28:27.574 am
info
sys:12026-10-25 6:55:53.033 am
info
sys:12026-10-25 6:55:32.321 am
info
sys:12026-10-25 6:55:32.286 am
info
sys:12026-10-25 6:46:10.213 am
info
sys:12026-10-25 6:44:28.179 am
info
sys:12026-10-25 6:44:28.110 am
info
sys:12026-10-24 5:16:31.971 pm
info
sys:12026-10-24 5:16:06.500 pm
info
sys:12026-10-24 5:16:06.453 pm
info
dev:52026-10-24 5:15:36.232 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[23],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected133","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:35.838 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[21],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected132","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:35.479 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[19],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected131","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:35.100 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[18],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected130","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:34.738 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[15],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected129","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:34.377 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[10],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected128","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:34.014 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[5],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected127","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:33.654 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[14],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected126","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:33.292 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[9],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected125","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:32.928 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[4],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected124","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:32.566 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[13],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected123","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:32.086 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[8],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected122","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:31.691 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[3],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected121","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:31.325 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[12],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected120","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:30.959 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[7],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected119","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:30.595 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[2],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected118","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:30.230 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[11],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected117","methodName":"get","nodeId":7},"response":1}]}
dev:52026-10-24 5:15:29.867 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[6],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected116","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:29.490 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected115","methodName":"get","nodeId":7},"response":0}]}
dev:52026-10-24 5:15:26.112 pm
debug
Association Report - Group: 1, Nodes: [01]
dev:52026-10-24 5:15:26.099 pm
debug
parse:{"cc":133,"cmd":3,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":133,"endpoint":0,"messageId":"expected113","methodName":"getGroup","nodeId":7},"response":{"maxNodes":10,"nodeIds":[1]}}]}
dev:52026-10-24 5:15:25.429 pm
debug
Device Specific Report - DeviceIdType: 1, DeviceIdFormat: 0, Data: [123, 100, 97, 116, 97, 61, 91, 49, 56, 56, 44, 32, 49, 52, 49, 44, 32, 49, 50, 54, 44, 32, 50, 53, 53, 44, 32, 50, 53, 52, 44, 32, 50, 53, 50, 44, 32, 52, 44, 32, 49, 52, 55, 93, 44, 32, 116, 121, 112, 101, 61, 66, 117, 102, 102, 101, 114, 125]
dev:52026-10-24 5:15:25.422 pm
debug
parse:{"cc":114,"cmd":7,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":114,"endpoint":0,"messageId":"expected112","methodName":"deviceSpecificGet","nodeId":7},"response":{"data":[188,141,126,255,254,252,4,147],"type":"Buffer"}}]}
dev:52026-10-24 5:15:25.073 pm
debug
Version2 Report - FirmwareVersion: 3.20, ProtocolVersion: 7.19, HardwareVersion: 3
dev:52026-10-24 5:15:25.061 pm
debug
parse:{"cc":134,"cmd":18,"ep":0,"values":[{"ccVersion":3,"newValue":3,"endpoint":0,"metadata":{"readable":true,"label":"Library type","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"11":"AV Device","0":"Unknown","1":"Static Controller","2":"Controller","3":"Enhanced Slave","4":"Slave","5":"Installer","6":"Routing Slave","7":"Bridge Controller","8":"Device under Test","9":"N/A","10":"AV Remote"}},"propertyName":"libraryType","commandClass":134,"property":"libraryType","commandClassName":"Version","value":3,"prevValue":3,"ts":1792876525030},{"ccVersion":3,"newValue":"7.19","endpoint":0,"metadata":{"readable":true,"label":"Z-Wave protocol version","secret":false,"writeable":false,"type":"string","stateful":true},"propertyName":"protocolVersion","commandClass":134,"property":"protocolVersion","commandClassName":"Version","value":"7.19","prevValue":"7.19","ts":1792876525029},{"ccVersion":3,"newValue":["3.20"],"endpoint":0,"metadata":{"readable":true,"label":"Z-Wave chip firmware versions","secret":false,"writeable":false,"type":"string[]","stateful":true},"propertyName":"firmwareVersions","commandClass":134,"property":"firmwareVersions","commandClassName":"Version","value":["3.20"],"prevValue":["3.20"],"ts":1792876525028},{"ccVersion":3,"newValue":3,"endpoint":0,"metadata":{"readable":true,"label":"Z-Wave chip hardware version","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"hardwareVersion","commandClass":134,"property":"hardwareVersion","commandClassName":"Version","value":3,"prevValue":3,"ts":1792876525018}]}
dev:52026-10-24 5:15:25.059 pm
debug
dev:52026-10-24 5:15:25.037 pm
debug
parse:{"cc":134,"cmd":18,"ep":0,"values":[{"request":{"args":[],"command":"endpoint.invoke_cc_api","commandClass":134,"endpoint":0,"messageId":"expected111","methodName":"get","nodeId":7},"response":{"firmwareVersions":["3.20"],"hardwareVersion":3,"libraryType":3,"protocolVersion":"7.19"}}]}
dev:52026-10-24 5:15:19.877 pm
debug
configure()
sys:12026-10-24 5:15:07.778 pm
info
Node 7 added without security at user request
sys:12026-10-24 5:15:05.242 pm
info
sys:12026-10-24 5:14:58.598 pm
info
sys:12026-10-24 5:14:58.568 pm
info
sys:12026-10-24 5:14:56.487 pm
info
Z-Wave exclusion stopped
sys:12026-10-24 5:14:54.096 pm
info
Z-Wave exclusion started
dev:42026-10-24 5:03:41.895 pm
info
East Bath Ceiling was turned off
dev:42026-10-24 5:03:41.891 pm
debug
parse:{"cc":37,"cmd":3,"ep":0,"values":[{"ccVersion":2,"newValue":false,"endpoint":0,"metadata":{"readable":true,"label":"Current value","secret":false,"writeable":false,"type":"boolean","stateful":true},"propertyName":"currentValue","commandClass":37,"property":"currentValue","commandClassName":"Binary Switch","value":false,"prevValue":true,"ts":1792875821880}]}
dev:42026-10-24 5:03:40.090 pm
info
East Bath Ceiling was turned on
dev:42026-10-24 5:03:40.067 pm
debug
parse:{"cc":37,"cmd":3,"ep":0,"values":[{"ccVersion":2,"newValue":true,"endpoint":0,"metadata":{"readable":true,"label":"Current value","secret":false,"writeable":false,"type":"boolean","stateful":true},"propertyName":"currentValue","commandClass":37,"property":"currentValue","commandClassName":"Binary Switch","value":true,"prevValue":false,"ts":1792875820051}]}
dev:42026-10-24 5:03:39.988 pm
debug
on()
dev:42026-10-24 5:03:38.893 pm
info
dev:42026-10-24 5:03:38.874 pm
debug
parse:{"cc":37,"cmd":3,"ep":0,"values":[{"ccVersion":2,"newValue":false,"endpoint":0,"metadata":{"readable":true,"label":"Current value","secret":false,"writeable":false,"type":"boolean","stateful":true},"propertyName":"currentValue","commandClass":37,"property":"currentValue","commandClassName":"Binary Switch","value":false,"prevValue":true,"ts":1792875818861}]}
dev:42026-10-24 5:03:38.752 pm
debug
off()
dev:42026-10-24 5:03:14.875 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[12],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected43","methodName":"get","nodeId":6},"response":1}]}
dev:42026-10-24 5:03:14.503 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[10],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected42","methodName":"get","nodeId":6},"response":0}]}
dev:42026-10-24 5:03:14.137 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[8],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected41","methodName":"get","nodeId":6},"response":2}]}
dev:42026-10-24 5:03:13.748 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[15],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected40","methodName":"get","nodeId":6},"response":1}]}
dev:42026-10-24 5:03:13.381 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[14],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected39","methodName":"get","nodeId":6},"response":1}]}
dev:42026-10-24 5:03:13.013 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[2],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected38","methodName":"get","nodeId":6},"response":0}]}
dev:42026-10-24 5:03:12.612 pm
debug
parse:{"cc":112,"cmd":6,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":112,"endpoint":0,"messageId":"expected37","methodName":"get","nodeId":6},"response":0}]}
dev:42026-10-24 5:03:12.241 pm
debug
dev:42026-10-24 5:03:12.222 pm
debug
parse:{"cc":133,"cmd":3,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":133,"endpoint":0,"messageId":"expected36","methodName":"getGroup","nodeId":6},"response":{"maxNodes":5,"nodeIds":[1]}}]}
dev:42026-10-24 5:03:11.532 pm
debug
Device Specific Report - DeviceIdType: 1, DeviceIdFormat: 0, Data: [123, 100, 97, 116, 97, 61, 91, 50, 50, 56, 44, 32, 56, 54, 44, 32, 49, 55, 50, 44, 32, 50, 53, 53, 44, 32, 50, 53, 52, 44, 32, 49, 48, 54, 44, 32, 51, 56, 44, 32, 51, 57, 93, 44, 32, 116, 121, 112, 101, 61, 66, 117, 102, 102, 101, 114, 125]
dev:42026-10-24 5:03:11.503 pm
debug
parse:{"cc":114,"cmd":7,"ep":0,"values":[{"request":{"args":[1],"command":"endpoint.invoke_cc_api","commandClass":114,"endpoint":0,"messageId":"expected35","methodName":"deviceSpecificGet","nodeId":6},"response":{"data":[228,86,172,255,254,106,38,39],"type":"Buffer"}}]}
dev:42026-10-24 5:03:11.105 pm
debug
Version2 Report - FirmwareVersion: 4.0, ProtocolVersion: 7.19, HardwareVersion: 4
debug
dev:42026-10-24 5:03:09.893 pm
debug
parse:{"cc":134,"cmd":18,"ep":0,"values":[{"ccVersion":3,"newValue":3,"endpoint":0,"metadata":{"readable":true,"label":"Library type","secret":false,"writeable":false,"type":"number","stateful":true,"states":{"11":"AV Device","0":"Unknown","1":"Static Controller","2":"Controller","3":"Enhanced Slave","4":"Slave","5":"Installer","6":"Routing Slave","7":"Bridge Controller","8":"Device under Test","9":"N/A","10":"AV Remote"}},"propertyName":"libraryType","commandClass":134,"property":"libraryType","commandClassName":"Version","value":3,"prevValue":3,"ts":1792875789813},{"ccVersion":3,"newValue":"7.19","endpoint":0,"metadata":{"readable":true,"label":"Z-Wave protocol version","secret":false,"writeable":false,"type":"string","stateful":true},"propertyName":"protocolVersion","commandClass":134,"property":"protocolVersion","commandClassName":"Version","value":"7.19","prevValue":"7.19","ts":1792875789810},{"ccVersion":3,"newValue":["4.0"],"endpoint":0,"metadata":{"readable":true,"label":"Z-Wave chip firmware versions","secret":false,"writeable":false,"type":"string[]","stateful":true},"propertyName":"firmwareVersions","commandClass":134,"property":"firmwareVersions","commandClassName":"Version","value":["4.0"],"prevValue":["4.0"],"ts":1792875789801},{"ccVersion":3,"newValue":4,"endpoint":0,"metadata":{"readable":true,"label":"Z-Wave chip hardware version","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"hardwareVersion","commandClass":134,"property":"hardwareVersion","commandClassName":"Version","value":4,"prevValue":4,"ts":1792875789787}]}
dev:42026-10-24 5:03:09.823 pm
debug
parse:{"cc":134,"cmd":18,"ep":0,"values":[{"request":{"args":[],"command":"endpoint.invoke_cc_api","commandClass":134,"endpoint":0,"messageId":"expected33","methodName":"get","nodeId":6},"response":{"firmwareVersions":["4.0"],"hardwareVersion":4,"libraryType":3,"protocolVersion":"7.19"}}]}
dev:42026-10-24 5:03:03.807 pm
debug
configure()
sys:12026-10-24 5:02:57.150 pm
info
Node 6 added without security at user request
sys:12026-10-24 5:02:50.051 pm
info
sys:12026-10-24 5:02:46.060 pm
info
sys:12026-10-24 5:02:45.943 pm
info
dev:12026-10-24 2:10:45.883 pm
warn
debug logging disabled...
sys:12026-10-24 2:00:14.950 pm
info
sys:12026-10-24 1:59:36.168 pm
info
sys:12026-10-24 1:59:36.128 pm
info
dev:22026-10-24 1:40:46.012 pm
warn
installed...
dev:12026-10-24 1:40:45.591 pm
warn
installed...
You do not want to post your hub ID in the public forum. You should edit the post and remove it.
I removed your hub ID from a public post. Never something you want to reveal publicly, FYI. Treat it like an (important) account #.
FYI, the fix for this has not been released yet.
Personally, I like "the fix is coming" rather than "here is a quick alpha/beta test it for me". Shows quality!
THANK YOU!!!!!!!!!
Thanks dude!
