Just one little thing - some sengled bulbs are very difficult to reset. About 8 months ago, I moved 8 from one Hubitat to another, and two RGBW bulbs wouldnât reset with the on/off sequence described by manufacturer (memory says 10 on/off cycles). It took me several such iterations before they reset - so be patient if it doesnât work right away.
Bear in mind that itâs much easier to migrate to a different Hubitat hub if you just have to move the one Hue hub.
I have lots of zigbee bulbs and I found it much easier to keep them on a separate hub and channel. Some bulbs are repeaters but they only work well repeating other bulbs. This keeps your bulb network separate from your sensor network and for me at least made things work better.
