Midea Dehumidifier
This is a custom driver for Midea Dehumidifier. tested working on Midea Cube.
based on
https://github.com/tomwpublic/hubitat_midea/blob/main/mideaAC_localController
https://github.com/nbogojevic/midea-beautiful-air/blob/main/midea_beautiful/command.py
metadata
    definition(name: "Midea Dehumidifier", namespace: "Chen", author: "Chen", importUrl: "")
        capability "Initialize"
        capability "Refresh"
        capability "Switch"
        capability "RelativeHumidityMeasurement"
		command "setFanSpeed", [[
			constraints: [ "High", "Low" ],
            type: "ENUM"]]
        command "setMode", [[
            constraints: [ "Set", "Continuous", "Max" ],
            type: "ENUM"]]
        command "setTargetHumidity", [[
            constraints: [ "35", "40", "45", "50", "55", "60", "65", "70", "75" ],
            type: "ENUM"]]
        attribute "Mode", "string"
        attribute "TargetHumidity", "number"
        attribute "FanSpeed", "string"
preferences
    section
        input name: "ipAddress", type: "text", title: "IP address", required: true
        input name: "port", type: "number", title: "port", required: true, defaultValue: 6444
        input name: "id", type: "number", title: "id", required: true
        input name: "token", type: "text", title: "token", required: true
        input name: "key", type: "text", title: "key", required: true
    section
        input ("refresh_Rate", "enum", title: "Device Refresh Interval (minutes)", options: ["1", "5", "10", "15", "30", "60", "180"], defaultValue: "5")
        input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def updated()
    state.errorCount = 0
 	unschedule()
    switch(refresh_Rate) {
		case "1" : runEvery1Minute(refresh); break
		case "5" : runEvery5Minutes(refresh); break
		case "10" : runEvery10Minutes(refresh); break
		case "15" : runEvery15Minutes(refresh); break
		case "30" : runEvery30Minutes(refresh); break
		case "180": runEvery3Hours(refresh); break
		default: runEvery1Hour(refresh)
    initialize()
def initialize()
    refresh()
def off()
    if( device.currentValue( "switch" ) != "off" )
        def data = ini_set_command( [switch: "off"] )
        apply(data)
def on()
    if( device.currentValue( "switch" ) != "on" )
        def data = ini_set_command( [switch: "on"] )
        apply(data)
def setMode(Mode)
    if( device.currentValue( "Mode" ) != Mode )
        def data = ini_set_command(["Mode": Mode] )
        apply(data)
def setFanSpeed(Speed)
    if( device.currentValue( "FanSpeed" ) != Speed )
        def data = ini_set_command(["FanSpeed": Speed] )
        apply(data)
def setTargetHumidity(Humidity)
    if( device.currentValue( "TargetHumidity" ) != Humidity.toInteger() )
        def data = ini_set_command(["TargetHumidity": Humidity.toInteger()])
        apply(data)
def refresh()
    if(getVolatileState("sessionActive"))
        logDebug("refresh(): socket access failed. another session is already in progress.")
        return
    try
//        unschedule(refresh)
        setVolatileState("sessionActive", true)
        if(!openSocket()) {throw new Exception("failed to open socket")}
        syncWait([waitSetter: "auth", timeoutSec: 4])
        runInMillis(20, '_authenticate')
        doWait()
        syncWait([waitSetter: "refresh", timeoutSec: 4])
        runInMillis(20, '_refresh')
        doWait()
    catch (Exception e)
        log.debug "error: refresh(): ${e.message}"
    finally
        closeSocket()
        setVolatileState("sessionActive", false)
//        runIn(refreshInterval ?: 60, refresh)
def apply(cmdParams)
        logDebug("apply(): socket access failed. another session is already in progress.")
        return
    try
        doWait()
        syncWait([waitSetter: "apply", timeoutSec: 4])
        runInMillis(20, '_apply', [data: cmdParams])
        doWait()
    catch (Exception e)
        log.debug "error: apply(): ${e.message}"
    finally
        closeSocket()
def logDebug(msg)
    if (logEnable)
        log.debug(msg)
def logHexBytes(data)
    String res = ""
    data.each
        res += String.format("%02X ", it & 0xFF)
    logDebug("bytes: ${res}")
    logDebug("string: ${hubitat.helper.HexUtils.byteArrayToHexString(data as byte[])}")
def socketStatus(String message)
    logDebug("socketStatus: ${message}")
def parse(String message)
    logDebug("parse: ${message}")
    def rdB = hubitat.helper.HexUtils.hexStringToByteArray(message)
    //logDebug("parse: ${rdB}")
    if(rdB.size() < 13)
        logDebug("ignoring short response")
        // clear this syncWait, likely set by connectSocket
        // note: the Midea units appear to return one 0x00 byte on connect.
        //    if this behavior changes, we will need a different signal to clear the wait.
        clearWait([waitSetter: "open"])
        return
    if(rdB.size() == 13)
        // just catch 'ERROR'
        rdB = subBytes(rdB, 8, 5)
        //logDebug("rdB = ${new String(rdB)}")
        return
    switch(getMsgType(rdB))
        case MSGTYPE_HANDSHAKE_RESPONSE:
            def tcp_key = tcp_key(rdB, key)
            if(tcp_key)
                setTcpKey(tcp_key)
                // clear this syncWait, likely set by _authenticate
                clearWait([waitSetter: "auth"])
            break
        case MSGTYPE_ENCRYPTED_RESPONSE:
            //logDebug("parse enc resp = ${rdB}")
            //logDebug("decode_8370 = ${decode_8370(rdB)}")
            def dec_8370 = decode_8370(rdB)
            if(([] != dec_8370) && (dec_8370.size() > (40 + 16)))
                def dec_resp = aes_ecb(subBytes(dec_8370, 40, dec_8370.size() - (40 + 16)), "dec")
                logDebug( "dec resp" + dec_resp )
                _process_response(dec_resp)
            break
def openSocket()
    logDebug("opening socket")
    interfaces.rawSocket.connect(ipAddress, port.toInteger(), byteInterface: true)
    // workaround: wait a little while to ensure the socket opened
    pauseExecution(20)
    return true
def closeSocket()
    try
        logDebug("closing socket")
        interfaces.rawSocket.close()
        // workaround: wait a little while to ensure the socket closed
        pauseExecution(500)
    catch (Exception e)
        // swallow errors
    return true
def _writeBytes(byte[] bytes)
    def wrStr = hubitat.helper.HexUtils.byteArrayToHexString(bytes)
    logDebug("writeBytes: ${wrStr}")
    interfaces.rawSocket.sendMessage(wrStr)
def _authenticate()
    def tokenBytes = hubitat.helper.HexUtils.hexStringToByteArray(token)
    logDebug("_authenticate packet follows:")
    request = encode_8370(tokenBytes, MSGTYPE_HANDSHAKE_REQUEST)
    _writeBytes(request)
def _refresh()
    def packet = packet_builder(id.toLong(), request_command())
    logDebug("_refresh packet follows:")
    appliance_transparent_send_8370(packet, MSGTYPE_ENCRYPTED_REQUEST)
def _apply(cmdParams)
    def packet = packet_builder(id.toLong(), cmdParams)
    logDebug("_apply packet follows:")
def _process_response(data)
    def resp
    if(data == 'ERROR'.getBytes())
        logDebug("response ERROR")
        return null
    if(200 == i8Tou8(data[0xA]))
        resp = appliance_response(data)
        logDebug("appliance_response: ${resp}")
        if(resp)
            _updateAttributes(resp)
            setVolatileState("state", resp)
        // clear this syncWait, possibly set by refresh()
        clearWait([waitSetter: "refresh"])
        // clear this syncWait, possibly set by _apply()
        clearWait([waitSetter: "apply"])
    return resp
def _updateAttributes(resp)
    if(!resp)
        return
    def events = [[:]]
    events +=    [name: "switch", value: resp.switch? "on":"off", isStateChange: true]
    events +=    [name: "FanSpeed", value: translateFanSpeed( resp.FanSpeed, "integer" ), isStateChange: true ]
    events +=    [name: "Mode",      value: translateMode( resp.Mode, "integer" ), isStateChange: true ]
    events +=    [name: "humidity",  value: resp.humidity, unit: "%", isStateChange: true]
    events +=    [name: "TargetHumidity", value: resp.TargetHumidity, isStateChange: true]
    events.each
        if( it.value != device.currentValue( it.name ) )
            sendEvent(it)
def translateMode(value, inputType)
    switch(inputType)
        case "integer":
            switch(value.toInteger())
                case 1:  return "Set"
                case 2:  return "Continuous"
                case 4:  return "Max"
                default: return "Set"
        case "string":
            switch(value)
                case "Set":        return 1
                case "Continuous": return 2
                case "Max":        return 4
                default:           return 1
        default:
            return
def translateFanSpeed(value, inputType)
    switch(inputType)
        case "integer":
                case 80: return "High"
                case 40: return "Low"
        case "string":
            switch(value)
                case "High": return 80
                case "Low" : return 40
        default:
            return
def appliance_response(data)
    // The response data from the appliance includes a packet header which we don't want
    data = subBytes(data, 0xA, data.size() - 0xA)
    def resp = [:]
    resp += [switch:          (data[1]&0x1) !=0  ]
    resp += [Mode:            data[2]&0b00001111 ]//1set, 2, cont, 3, max
    resp += [humidity:        data[16]           ]
    resp += [TargetHumidity:  data[7]            ]
    resp += [FanSpeed:        data[3]&0b01111111 ]
    return resp
def setTcpKey(key)
    setVolatileState('tcp_key', key)
def getTcpKey()
    getVolatileState('tcp_key')
def request_command()
    byte[] req =
        // 0 header
        0xaa,
        // 1 command lenght: N+10
        0x20,
        // 2 device type (0xAC for air conditioner)
        0xa1,
        // 3 Frame SYN CheckSum
        0x00,
        // 4-5 Reserved
        0x00, 0x00,
        // 6 Message ID
        0x00,
        // 7 Frame Protocol Version
        0x00,
        // 8 Device Protocol Version
        0x00,
        // 9 Message Type: request is 0x03; setting is 0x02
        0x03,
        // Byte0 - Data request/response type: 0x41 - check status; 0x40 - Set up
        0x41,
        // Byte1
        0x81,
        // Byte2 - operational_mode
        0x00,
        // Byte3
        0xff,
        // Byte4
        0x03,
        // Byte5
        0xff,
        // Byte6
        0x00,
        // Byte7 - Room Temperature Request: 0x02 - indoor_temperature, 0x03 - outdoor_temperature
        // when set, this is swing_mode
        0x00,
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
        // Message ID
        (state.request_count ?: 1) & 0xFF
    return req
def ini_set_command(params)
    byte[] data =
        //Sync header
        0xAA,
        // Length
        0x20,
        // Device type: Dehumidifier
        0xA1,
        // Frame synchronization check
        0x00,
        // Reserved
        0x00,
        0x00,
        // Message id
        0x00,
        // Framework protocol
        0x00,
        // Home appliance protocol
        0x03,
        // Message Type: querying is 0x03; control is 0x02
        0x02,
        // Payload
        // Data request/response type:
        // 0x41 - check status
        // 0x48 - write
        0x48,
        // Flags: On bit0 (byte 11)
        0x00,
        // Mode (byte 12)
        0x01,
        // Fan (byte 13)
        0x32,
        0x00,
        0x00,
        0x00,
        // Humidity (byte 17)
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
        0x00,
    [ "switch", "Mode", "FanSpeed", "TargetHumidity" ].each{
        if( !params.containsKey( it ) )
            params[ it ] = device.currentValue( it )
    //Switch
    data[11] &= ~0b00000001  // Clear the power bit
    data[11] |= params.switch == "on"? 0b00000001:0
    //Mode
    data[12] &= ~0b00001111  // Clear the mode bits
    data[12] |= translateMode(params["Mode"], "string" )
    //Fan Speed
    data[13] &= ~0b01111111  // Clear the fan speed part
    data[13] |= translateFanSpeed(params["FanSpeed"], "string" ) & 0b01111111
    //Target Humidity
    data[17] &= ~0b01111111  // Clear the humidity part
    data[17] |= params["TargetHumidity" ]
    return data
import groovy.transform.Field
@Field MSGTYPE_HANDSHAKE_REQUEST = 0x0
@Field MSGTYPE_HANDSHAKE_RESPONSE = 0x1
@Field MSGTYPE_ENCRYPTED_RESPONSE = 0x3
@Field MSGTYPE_ENCRYPTED_REQUEST = 0x6
@Field MSGTYPE_TRANSPARENT = 0xf
import java.security.MessageDigest
def getMsgType(header)
    if(i8Tou8(bytesToInt([header[0]], "big")) != 0x83 || i8Tou8(bytesToInt([header[1]], "big")) != 0x70)
        logDebug("not an 8370 message")
        return -1
    if(header.size() < 6)
        logDebug("header too short")
        return -1
    def msgtype = i8Tou8(bytesToInt([header[5]], "big")) & 0xf
def encode_8370(data, msgtype)
    byte[] header = [i8Tou8(0x83), i8Tou8(0x70)]
    def size = data.size()
    def padding = 0
    if(msgtype in [MSGTYPE_ENCRYPTED_RESPONSE, MSGTYPE_ENCRYPTED_REQUEST])
        if((size + 2) % 16 != 0)
            padding = 16 - ((size + 2) & 0xf)
            size += (padding + 32)
            byte[] pBytes = new byte[padding]
            new Random().nextBytes(pBytes)
            data = appendByteArr(data, pBytes)
    header = appendByteArr(header, intToBytes(size, 2, "big"))
    header = appendByteArr(header, [i8Tou8(0x20), i8Tou8(padding << 4 | msgtype)])
    def request_count = state.request_count ?: 0
    data = appendByteArr(intToBytes(request_count, 2, "big"), data)
    state.request_count = request_count + 1
        MessageDigest digest = MessageDigest.getInstance("SHA-256")
        def sign = digest.digest(appendByteArr(header, data))
        // if tcp_key isn't available, just use a random key
        data = aes_cbc(data, "enc", getTcpKey() ?: '4D67055D53288313335D65FB2CBA3DDB04001F8AF6880CBDB5BC45DA67EC8A35')
        data = appendByteArr(data, sign)
    return appendByteArr(header, data)
def decode_8370(data)
    def header = subBytes(data, 0, 6)
    data = subBytes(data, 6, data.size() - 6)
        return []
    if(i8Tou8(bytesToInt([header[4]], "big")) != 0x20)
        logDebug("missing byte 4")
        return []
    def padding = i8Tou8(bytesToInt([header[5]], "big")) >> 4
    def msgtype = getMsgType(header)
    def size = i16Tou16(bytesToInt(subBytes(header, 2, 2), "big"))
    if(data.size() < (size + 2))
        // request_count was not in size, so count 2 extra bytes here
        logDebug("data.size() = ${data.size()}, size + 2 = ${size + 2}")
        return []
        sign = subBytes(data, data.size() - 32, 32)
        data = subBytes(data, 0, data.size() - 32)
        data = aes_cbc(data, "dec", getTcpKey() ?: '4D67055D53288313335D65FB2CBA3DDB04001F8AF6880CBDB5BC45DA67EC8A35')
        def check = digest.digest(appendByteArr(header, data))
        if(check != sign)
            logDebug("sign does not match")
            return []
        if(padding)
            data = subBytes(data, 0, data.size() - padding)
    state.response_count = i16Tou16(bytesToInt(subBytes(data, 0, 2), "big"))
    data = subBytes(data, 2, data.size() - 2)
    return data
import javax.crypto.spec.SecretKeySpec
import javax.crypto.spec.IvParameterSpec
import javax.crypto.Cipher
@Field signKey = 'xhdiwjnchekd4d512chdjx5d8e4c394D2D7S'.getBytes()
def aes_cbc(data, op = "enc", key = key)
    // thanks: https://community.hubitat.com/t/groovy-aes-encryption-driver/31556
    def cipher = Cipher.getInstance("AES/CBC/NoPadding", "SunJCE")
    // note: we already have the key from midea-smart
    byte[] keyBytes = hubitat.helper.HexUtils.hexStringToByteArray(key)
    SecretKeySpec aKey = new SecretKeySpec(keyBytes, 0, keyBytes.length, "AES")
    //self.iv = b'\0' * 16
    def IVKey = '\0' * 16
    IvParameterSpec iv = new IvParameterSpec(IVKey.getBytes("UTF-8"))
    cipher.init(op == "enc" ? Cipher.ENCRYPT_MODE : Cipher.DECRYPT_MODE, aKey, iv)
    return cipher.doFinal(data)
def aes_ecb(data, op = "enc")
    def encKey = md5(signKey)
    SecretKeySpec aKey = new SecretKeySpec(encKey, 0, encKey.length, "AES")
    def cipher = Cipher.getInstance("AES/ECB/PKCS5Padding", "SunJCE")
    cipher.init(op == "enc" ? Cipher.ENCRYPT_MODE : Cipher.DECRYPT_MODE, aKey)
def md5(data)
    MessageDigest digest = MessageDigest.getInstance("MD5")
    digest.update(data)
    byte[] md5sum = digest.digest()
    return md5sum
def tcp_key(response, key = key)
    if(subBytes(response, 8, 5) == 'ERROR'.getBytes())
        logDebug("authentication failed")
        return null
    if(response.size() != 72)
        logDebug("unexpected data length")
        return null
    response = subBytes(response, 8, 64)
    def payload = subBytes(response, 0, 32)
    def sign = subBytes(response, 32, 32)
    def plain = aes_cbc(payload, "dec", key)
    if(sign != digest.digest(plain))
        return null
    if(plain.size() != keyBytes.size())
        logDebug("size mismatch")
        return null
    (0..(plain.size() - 1)).each
        // tcp_key = strxor(plain, key)
        plain[it] = plain[it] ^ keyBytes[it]
    def tcp_key = hubitat.helper.HexUtils.byteArrayToHexString(plain)
    state.request_count = 0
    state.response_count = 0
    return tcp_key
def appliance_transparent_send_8370(data, msgtype=MSGTYPE_ENCRYPTED_REQUEST)
    if(!getTcpKey())
        logDebug("missing tcp_key.  need to _authenticate")
        return
    def sData = subBytes(data, 0, data.size())
    sData = encode_8370(sData, msgtype)
    _writeBytes(sData)
def packet_builder(device_id, command)
    // Init the packet with the header data
    def packet =
            // 2 bytes - StaicHeader
            0x5a, 0x5a,
            // 2 bytes - mMessageType
            0x01, 0x11,
            // 2 bytes - PacketLenght
            0x00, 0x00,
            // 2 bytes
            0x20, 0x00,
            // 4 bytes - MessageId
            // 8 bytes - Date&Time
            // 6 bytes - mDeviceID
            // 12 bytes
            0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
    //self.packet[12:20] = self.packet_time()
    //'%Y%m%d%H%M%S%f'
    def dateBytes = hubitat.helper.HexUtils.hexStringToByteArray(new Date().format('yyyyMMddHHmmssSSSS'))
    packet = replaceSubArr(packet, subBytes(dateBytes, 0, 8), 12)
    //self.packet[20:28] = device_id.to_bytes(8, 'little')
    packet = replaceSubArr(packet, intToBytes(device_id, 8, "little"), 20)
    // base_command.finalize()
    // Add the CRC8
    def crc = crc8(subBytes(command, 10, command.size() - 10))
    command = appendByteArr(command, [i8Tou8(crc)])
    // Set the length of the command data
    // self.data[0x01] = len(self.data)
    // Add checksum
    def checksum = checksum(subBytes(command, 1, command.size() - 1))
    command = appendByteArr(command, [i8Tou8(checksum)])
    // packet_builder.finalize()
    def encCmd = aes_ecb(command, "enc")
    // Append the command data(48 bytes) to the packet
    packet = appendByteArr(packet, subBytes(encCmd, 0, 48))
    // PacketLength
    packet = replaceSubArr(packet, intToBytes(packet.size() + 16, 2, "little"), 4)
    // Append a basic checksum data(16 bytes) to the packet
    packet = appendByteArr(packet, md5(appendByteArr(packet, signKey)))
    return packet
def appendByteArr(a, b)
    byte[] c = new byte[a.size() + b.size()]
    a.eachWithIndex()
        it, i ->
        c[i] = it
    def aSz = a.size()
    b.eachWithIndex()
        it, i ->
        c[i + aSz] = it
    return c
def replaceSubArr(orig_arr, new_arr, start)
    def tmp_arr = orig_arr.collect()
    new_arr.eachWithIndex
        it, i ->
        tmp_arr[i + start] = it
    return tmp_arr
private subBytes(arr, start, length)
    byte[] sub = new byte[length]
    for(int i = 0; i < length; i++)
        sub[i] = arr[i + start]
    return sub
def swapEndiannessU16(input)
    return [i8Tou8(input[1]), i8Tou8(input[0])]
def swapEndiannessU32(input)
    return [input[3], input[2], input[1], input[0]]
def swapEndiannessU64(input)
    return [input[7], input[6], input[5], input[4],
def intToBytes(input, width, endian = "little")
    def output = new BigInteger(input).toByteArray()
    if(output.size() > width)
        // if we got too many bytes, lop off the MSB(s)
        output = subBytes(output, output.size() - width, width)
        output = output.collect{it & 0xFF}
    byte[] pad
    if(output.size() < width)
        def padding = width - output.size()
        pad = [0] * padding
        output = appendByteArr(pad, output)
    if("little" == endian)
        switch(width)
            case 1:
                break
            case 2:
                output = swapEndiannessU16(output)
                break
            case 4:
                output = swapEndiannessU32(output)
                break
            case 8:
                output = swapEndiannessU64(output)
                break
    return output.collect{it & 0xFF}
def bytesToInt(input, endian = "little")
    def output = subBytes(input, 0, input.size())
    long retVal = 0
    output.eachWithIndex
        it, i ->
        switch(endian)
            case "little":
                retVal += ((it & 0xFF).toLong() << (i * 8))
                break
            case "big":
            default:
                retVal += (it & 0xFF).toLong() << ((output.size() - 1 - i) * 8)
                break
    if(input.size() == 8)
        // 8 bytes is too big for integer
        return retVal
    return retVal as Integer
def i8Tou8(input)
    return input & 0xFF
def i16Tou16(input)
    return input & 0xFFFF
def getBit(pByte, pIndex)
    return (pByte >> pIndex) & 0x01
def getBits(pBytes, pIndex, pStartIndex, pEndIndex)
    if(pStartIndex > pEndIndex)
        StartIndex = pEndIndex
        EndIndex = pStartIndex
    else
        StartIndex = pStartIndex
        EndIndex = pEndIndex
    tempVal = 0x00
    StartIndex.upto(EndIndex)
        tempVal = tempVal | getBit(pBytes[pIndex], it) << (it - StartIndex)
    return tempVal
@Field crc8_854_table =
    0x00, 0x5E, 0xBC, 0xE2, 0x61, 0x3F, 0xDD, 0x83,
    0xC2, 0x9C, 0x7E, 0x20, 0xA3, 0xFD, 0x1F, 0x41,
    0x9D, 0xC3, 0x21, 0x7F, 0xFC, 0xA2, 0x40, 0x1E,
    0x5F, 0x01, 0xE3, 0xBD, 0x3E, 0x60, 0x82, 0xDC,
    0x23, 0x7D, 0x9F, 0xC1, 0x42, 0x1C, 0xFE, 0xA0,
    0xE1, 0xBF, 0x5D, 0x03, 0x80, 0xDE, 0x3C, 0x62,
    0xBE, 0xE0, 0x02, 0x5C, 0xDF, 0x81, 0x63, 0x3D,
    0x7C, 0x22, 0xC0, 0x9E, 0x1D, 0x43, 0xA1, 0xFF,
    0x46, 0x18, 0xFA, 0xA4, 0x27, 0x79, 0x9B, 0xC5,
    0x84, 0xDA, 0x38, 0x66, 0xE5, 0xBB, 0x59, 0x07,
    0xDB, 0x85, 0x67, 0x39, 0xBA, 0xE4, 0x06, 0x58,
    0x19, 0x47, 0xA5, 0xFB, 0x78, 0x26, 0xC4, 0x9A,
    0x65, 0x3B, 0xD9, 0x87, 0x04, 0x5A, 0xB8, 0xE6,
    0xA7, 0xF9, 0x1B, 0x45, 0xC6, 0x98, 0x7A, 0x24,
    0xF8, 0xA6, 0x44, 0x1A, 0x99, 0xC7, 0x25, 0x7B,
    0x3A, 0x64, 0x86, 0xD8, 0x5B, 0x05, 0xE7, 0xB9,
    0x8C, 0xD2, 0x30, 0x6E, 0xED, 0xB3, 0x51, 0x0F,
    0x4E, 0x10, 0xF2, 0xAC, 0x2F, 0x71, 0x93, 0xCD,
    0x11, 0x4F, 0xAD, 0xF3, 0x70, 0x2E, 0xCC, 0x92,
    0xD3, 0x8D, 0x6F, 0x31, 0xB2, 0xEC, 0x0E, 0x50,
    0xAF, 0xF1, 0x13, 0x4D, 0xCE, 0x90, 0x72, 0x2C,
    0x6D, 0x33, 0xD1, 0x8F, 0x0C, 0x52, 0xB0, 0xEE,
    0x32, 0x6C, 0x8E, 0xD0, 0x53, 0x0D, 0xEF, 0xB1,
    0xF0, 0xAE, 0x4C, 0x12, 0x91, 0xCF, 0x2D, 0x73,
    0xCA, 0x94, 0x76, 0x28, 0xAB, 0xF5, 0x17, 0x49,
    0x08, 0x56, 0xB4, 0xEA, 0x69, 0x37, 0xD5, 0x8B,
    0x57, 0x09, 0xEB, 0xB5, 0x36, 0x68, 0x8A, 0xD4,
    0x95, 0xCB, 0x29, 0x77, 0xF4, 0xAA, 0x48, 0x16,
    0xE9, 0xB7, 0x55, 0x0B, 0x88, 0xD6, 0x34, 0x6A,
    0x2B, 0x75, 0x97, 0xC9, 0x4A, 0x14, 0xF6, 0xA8,
    0x74, 0x2A, 0xC8, 0x96, 0x15, 0x4B, 0xA9, 0xF7,
    0xB6, 0xE8, 0x0A, 0x54, 0xD7, 0x89, 0x6B, 0x35
int crc8(value)
    // thanks: http://www.java2s.com/example/java-utility-method/crc-calculate/crc8-string-value-6f7a7.html
    int crc = 0
    for (int i = 0; i < value.size(); i++)
        crc = crc8_854_table[value[i] ^ (crc & 0xFF)]
    return crc
def checksum(data)
    def sum = data.sum()
    return (~ sum + 1) & 0xFF
def encode(byte[] data)
    data.collect { it & 0xFF }
// volatile state and sync code below
@Field static volatileState = [:].asSynchronized()
def setVolatileState(name, value)
    def tempState = volatileState[device.getDeviceNetworkId()] ?: [:]
    tempState.putAt(name, value)
    volatileState.putAt(device.getDeviceNetworkId(), tempState)
    return volatileState
def getVolatileState(name)
    return volatileState.getAt(device.getDeviceNetworkId())?.getAt(name) ?: null
def syncWait(data)
    // set up for checking 5x per second
    setVolatileState("syncWaitDetails", [waitSetter: data.waitSetter, retryCount: data.timeoutSec * 5])
def doWait()
    def wtDetails = getVolatileState("syncWaitDetails")
    // check every 200 ms whether the wait was cleared...
    if(wtDetails?.waitSetter == "")
        return
    // ...or throw an exception if we ran out of tries
    if(wtDetails?.retryCount == 0)
        throw new Exception("wait timed out")
    wtDetails.putAt("retryCount", wtDetails.getAt("retryCount") - 1)
    setVolatileState("syncWaitDetails", wtDetails)
    pauseExecution(200)
    doWait()
def clearWait(data)
    if(data.waitSetter == wtDetails?.getAt("waitSetter"))
        syncWait([waitSetter: "", timeoutSec: 0])
def clearAllWaits()
This is awesome. I have a Danby window A/C that use an app called NetHome Plus.
Which app does the Midea use? I'm guessing if my A/C works with the Midea app, I can use it on my A/C ?
I use Midea Air app
Thanks, how did you get the token, port, key & ID? Is there a link you could share?
GitHub - tomwpublic/hubitat_midea
I followed this instruction.
you will need a machine with python3. ideally a linux machine. i used raspberry pi.
to run
pip3 install msmart
midea-discover
If you are using this with an AC, check out my integration: Midea Mini Split Wifi Support - #11 by tomw
I'm glad you found it useful @Chen555, and I appreciate you linking to my original AC code from your dehumidifier integration.
you've done an excellent job on the AC driver. it made things much easier for the dehumidifier.
Sweet!
I was able to load Python onto my Windows laptop and make this work as well.
  1. Downloaded the zip file with the python (msmart) routines & extracted the zip files
  2. Downloaded the Python 3.x Windows Installer
  3. Installed Python 3.x by running the installer (MUST add the install location to the path)
  4. Open a command prompt
  5. Navigate into the zip file extraction to the directory containing the "msmart" directory
  6. pip3 install msmart
  7. Ran: midea-discover -i
I'm new with Hubitat, but a add Tank Level a this code
Capture d’écran, le 2023-06-26 à 08.58.44
ask me, if any want
Please know this worked for a Danby Dehumidifier Model: DDR050BLPBDB-ME
Hi, yes, please share.
add the following line after line: attribute "FanSpeed", "string"
attribute "TankLevel", "number"
and add the following line after line: resp += [FanSpeed: data[3]&0b01111111 ]
resp += [TankLevel: data[10]&0b01111111 ]
let me know if it works. I didn't add tank level because I use a drain hose instead of the water tank, so I never need to empty the tank.
Thank you, something working. I can report back the results.
There was a third line I added after events += [name: "TargetHumidity", value: resp.TargetHumidity, isStateChange: true]
events += [name: "TankLevel", value: resp.TankLevel, isStateChange: true]
Additionally there is a third mode "3" on the dehumidifier. I plan to play with it.
so close but there more info
i change Tanklevel by Waterlevel
add line 33
add line 376
add line 445
and save
I got to the point of running midea-discover, but it's throwing errors. I tried with the -i as well, but also get an error
C:\midea-msmart-master>midea-discover
INFO:msmart.cli:msmart version: 0.2.5 Currently only supports ac devices, only support MSmartHome and 美的美居 APP.
INFO:msmart.cloud:Using Midea cloud server: https://mp-prod.appsmb.com/mas/v5/app/proxy?alias= False
Traceback (most recent call last):
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "C:\Program Files\Python311\Scripts\midea-discover.exe\__main__.py", line 7, in <module>
  File "C:\Program Files\Python311\Lib\site-packages\click\core.py", line 1157, in __call__
    return self.main(*args, **kwargs)
  File "C:\Program Files\Python311\Lib\site-packages\click\core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "C:\Program Files\Python311\Lib\site-packages\click\core.py", line 1434, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "C:\Program Files\Python311\Lib\site-packages\click\core.py", line 783, in invoke
    return __callback(*args, **kwargs)
  File "C:\Program Files\Python311\Lib\site-packages\msmart\cli.py", line 51, in discover
    found_devices = loop.run_until_complete(discovery.get_all() if ip == '' else discovery.get(ip))
  File "C:\Program Files\Python311\Lib\asyncio\base_events.py", line 653, in run_until_complete
    return future.result()
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 193, in get_all
    await self._process_tasks(tasks)
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 199, in _process_tasks
    [self.result.add(task.result()) for task in tasks]
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 199, in <listcomp>
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 50, in support_test
    _device = await self.support_testv3(account, password)
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 65, in support_testv3
    token, key = await loop.run_in_executor(None, gettoken, udpid, account, password)
  File "C:\Program Files\Python311\Lib\concurrent\futures\thread.py", line 58, in run
    result = self.fn(*self.args, **self.kwargs)
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 255, in gettoken
    Client.login()
  File "C:\Program Files\Python311\Lib\site-packages\msmart\cloud.py", line 143, in login
    self.get_login_id()
  File "C:\Program Files\Python311\Lib\site-packages\msmart\cloud.py", line 132, in get_login_id
    response = self.api_request(
  File "C:\Program Files\Python311\Lib\site-packages\msmart\cloud.py", line 121, in api_request
    return self.api_request(endpoint, args)
  File "C:\Program Files\Python311\Lib\site-packages\msmart\cloud.py", line 123, in api_request
    raise RecursionError()
RecursionError
midea-discover -i
C:\midea-msmart-master>midea-discover -i 192.168.3.176
  File "C:\Program Files\Python311\Lib\site-packages\msmart\scanner.py", line 205, in get
    await self._process_tasks([task])
    Client.login()
    self.get_login_id()
RecursionError
midea-discover -d
C:\midea-msmart-master>midea-discover -d
INFO:msmart.cli:Debug mode active
DEBUG:asyncio:Using proactor: IocpProactor
DEBUG:msmart.scanner:Broadcast message sent: 1
DEBUG:msmart.scanner:Midea Local Data 192.168.3.176 837000c8200f00005a5a0111b8007a800000000073550a16020817149b10030000890000000000000000018000000000bb9dea41f9ca5a1c8f0985756b1677c15bf6e9e247aabb84ad24fc6929dae76bbfb2e7338d33381f3074629c1e4a631e7380637d148be3239f9295641903dceaa4e2e0e3b8ca6e92fbc3b25561f8b3d1f62b1d8bb9e5c25dba7bf8e0cc4c77944bdfb3e16e33d88768cc4c3d0658937d0bb19369bf0317b24d3a4de9e6a13106a1a3d5a05142b307fb7a775ff57eed0f08f7b399256d5231a61970c29a957510
DEBUG:msmart.scanner:Decrypt Reply: 192.168.3.176 b003a8c02c19000030303030303050303030303030305131414339334334304638374345303030300b6e65745f61315f383743450000870002000000000000000000a100a1a100000000ac93c40f87ce150023082122000300000000000000000000000000000000000000000000000000000000000000000000
DEBUG:msmart.scanner:Socket timeout
DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): mp-prod.appsmb.com:443
DEBUG:urllib3.connectionpool:https://mp-prod.appsmb.com:443 "POST /mas/v5/app/proxy?alias=/v1/user/login/id/get HTTP/1.1" 200 41
DEBUG:msmart.cloud:Response: {"code":"3004","msg":"value is illegal."}
DEBUG:msmart.cloud:Error ignored: '3004' - 'value is illegal.'
DEBUG:msmart.cloud:Retrying API call: '/v1/user/login/id/get'
    Client.login()
    self.get_login_id()
RecursionError
I am getting the same issue you are getting @jason.o.brown. I would appreciate if anyone knows what is causing this problem?
Rob9 do this instructions
I don't know if that changes anything but in 4 did you run command prompt in admin?
for my part, I retrieved the information on my mac
At this point, sorry but I don't recall. You could try it, perhaps.
sorry my friend, a try to help @jason.o.brown
I'm getting this exact error as well. I tried installing new MSmart APP as well as Midea (old) app registering a new account on each. The Midea Discover is able to find the Midea device on my LAN but is not able to connect to the Midea Cloud. Hence, it can't pull the needed token, port, key & ID to complete the driver setup on habitat.
