Metadata error
I am just getting starting with a new Hubitat C7 and after loading the "Konnected Pro" code from Github that was linked on the Konnected site successfully. The next item to load is the Konnected Pro Device app. When I try to save this app, I am getting this Metadata error...
Metadata Error: Parent App 'konnected-io:Konnected Pro' not found on line 18
The "Konnected Pro" loaded and is showing up under Apps. These are the first apps that I am attempting to install. I figure I am missing some basic step getting started with the Hub.
Any suggestions would be appreciated.
This? GitHub - konnected-io/konnected-hubitat: Konnected Apps and Drivers for Hubitat home automation hub
Make sure anything in the "Apps" folder you load to the App Code o the hub.
Anything in the drivers folder goes to the Driver Code.
Easiest way to load them is to visit the "RAW" link, then copy the URL an use the import feature in the code editor. Just make sure Apps go in apps and Drivers go in drivers.
Thanks for the response!
My problem was (and will be the problem of anyone else) that the links given for the needed apps on the konnected web page do not work. Using the later versions from GitHub worked fine. Perhaps there is a place for someone new to reference the needed / recommended apps vs. firmware of devices etc...?
I am currently using all of applicable apps and drivers here GitHub - konnected-io/konnected-hubitat: Konnected Apps and Drivers for Hubitat home automation hub.
I am getting close on fine-tuning my konnected pro and will tackle next considerations for a wall mounted dashboard.
Sounds like a job for @nate :slight_smile:
