I'm looking to go down the Meshtastic rabbit hole. It uses 915mhz. Hubitat Zwave uses 908.4mhz. I'm wondering if there'll be any interference from anyone with experience. Thanks!
I have a Meshtastic repeater outside my home. Never seen any interference. It was a fun project but has little use since there are so few repeaters in my area.
What does it mean when the hub says : US-LR - 908.4 Mhz, 916 Mhz ?
How is 916 in the mix?
I have no idea.
I'm not sure either. Search results suggest 908.4 is the one, so I'm not sure where the 916 comes from.
Per Google…
The USA uses 916 MHz in combination with 908.4 MHz for Z-Wave mesh networking. These frequencies are part of the U.S. sub-gigahertz ISM band required for FCC certification. The 916 MHz frequency is often used for higher bandwidth traffic or alongside the primary 908.4 MHz signal to reduce interference.
Key details about Z-Wave frequencies in the USA:
- Primary Frequencies: 908.4 MHz and 916 MHz.
- Z-Wave Long Range (LR): Operates at 912–920 MHz.
The 916 MHz band is frequently used by newer 700 and 800 series Z-Wave devices for better performance, acting as a secondary channel to the legacy 908.4 MHz frequency.
that narrows it down
You're welcome!
Hey, I put some words in a search engine as well before posting.
Clear as mud. 912-920. okay.
z-wave LR uses spread spectrum frequency hopping. So it will spread around between 912 and 920.
I saw this thread and thought I would chime in, So far I have 3 Meshtastic nodes (LoRa) in my home. One outside acting as a repeating client for the neighborhood and one inside acting as a MQTT bridge to take MQTT traffic and move it from the topic to the LoRa mesh and forward LoRa traffic to MQTT topic. The 3rd radio is mine I use it to monitor the LaRa in our region: https://chimesh.org
I have yet to see any Z-Wave issues and the bandwidth on the LoRa is only utilized at about 20% I have no Long Range Z-Wave devices and I have a mix if 1st Gen Inovelli Red’s, 3 Gen Inovelli Red’s and a few of the Honeywell Z-Wave switches from when Costco sold them. Dome water sensors, Dome contact sensors, and a Z-Wave door chime / alarm chime and two locks. In total 30 devices with a mix of 300, 500, and 700 series chips.
Thank you. That’s the sort of helpful information sharing we need. Experience rather than mere opinion. Greatly appreciated.
