Hi All I'm playing around with 2 hubs learning and what I'm trying to do is mesh my 2 hubs and bring the lets say sensor device from my second Hub to the main Hub so I can add it to my device list on my main hub so as to include that sensor device into the main hub dashboard. Then use Mira. Can this be done? I tried many different ways with no success.
John
You're not giving us much to go on...
When you visit Settings:Hub Mesh, is it Enabled and you see the other hub(s)?
If you see this, then enable it and reboot. Check the other hub too. They should see each other.
You can't see it in the list of devices to add to a specific Dashboard?
Apps: Dashboard
You named your Dashboard with a better name, right?
Yes, All is working fine after a reboot on both hubs. Thanks for the fast reply and help.
John
