@ajardolino3,
Thank you for your step-by-step explanation. I followed them, but got an error again.
Suddenly I noticed that the quotes around TOKEN are different than in the rest of the script. I changed them and then it worked.
Thank you so much for your script and the time you put into it. My garage door finally works in Hubitat
@ajardolino3 The version number code change resolved this for me. I had everything else configured properly, but was pounding my head about why my device wasn't responding. I had previously noticed those 0s in the driver code (Thinking "Is there really a version zero?!), but couldn't quite process what to do about it.
Since previously giving up on this, I ended up using the (convoluted and somewhat unreliable) IFTTT approach that others have used. This is working so much better than that. Thanks!
Only problem with using IFTTT is now you are dependent on the internet for your garage door to work. Someone should really update the device driver for hubitat so it pulls the UUIDs automatically for you instead of having to run javascript in a browser console. @ithinkdancan - is this possible?
