Mercator Ikuu
Has anyone got the 6-gang wall switch working?
Delightfully it does use its neutral and powers up without any loads, but I can't get it working in Hubitat. I've tried the built in Generic Multi-endpoint switch and the community Zemismart one without success.
Product - Six Switch | Ikuü (ikuu.com.au)
Data:
  • endpointId: 01
  • application: 41
  • isMultiEP: false
  • manufacturer: _TZE200_wnp4d4va
  • model: TS0601
Thank you so much for this. I know it's an old post but keen to understand if this would work on a C5 hub.
@luke2 @JoelD you can try this driver.
The fingerprint of this particular six-switch device is not in the driver at the moment, but let me know whether the first four switches work or not.
@kkossev - yep, that works great for the first 4 gangs! Do you have plans to scale it out to 6 gang?
I have bookmarked this, but as here in Europe, we are facing the winter heating season energy saving challenges, now the priority is the TRVs / thermostats .. : )
I got one of these to try out: Double Power Point IP54 | Ikuü
but i can't find a working driver that gives me control of both switches. Id really appreciate if someone knows which works. I've tired 5 from the community but no luck.
The built in "Generic Zigbee Multi-Endpoint Switch" works fine for this and the indoor doubles and quads fine for me.
Hi KKossev, I ended up buying a 6 gang and a 5 gang switches without knowing the driver issue. I see now that other people have not been able to get it working like myself, I paid a fortune for the electrician to run neutral wires to 2 of my old wall switches to accommodate the new zigbee ones.
Have you done any further work recently on the driver for those?
Lets follow up in the other thread.
Is there a driver for the inline dimmer switch? I am planning to buy it but just want to be sure if it will work with hubitat?
I just bought 2 of these and waiting to arrive. Did you get them working without the ikuu hub? I'm guessing I'm wandering into a sh#tstorm. I do have good chatgpt skills and got it to fix some wiz drivers but this ikuu is another thing altogether
I use Plugbase | Ikuü and the "generic zigbee outlet" works perfectly for that.
I’m using this driver from @gslender for my dimmer switch https://raw.githubusercontent.com/gslender/hubitat/main/ikuu-zigbee-single-gang-light-dimmer.groovy
If you get stuck with the built-in drivers, this one might work
Im keen to buy one of these. Maybe ill buy one to test as i dont want to get stuck with gear thats only half working. https://www.sparkydirect.com.au/p/Mercator-Ikuu-SSWD01G-Smart-Single-Dimmer-Light-Switch-Zigbee
It works as advertised. Though note that it is not using a neutral so you need to have a high enough load on the circuit to keep the radio in the switch operating. If you don’t have a high enough load you’ll have to add a load correction device to it as well.
