I'm in the process of buying a new house. I'm planning on moving all my current smarthome gear over. It's mostly Zooz zwave switches, motion sensors, open/close sensors, and temp sensors. Most of the devices are zwave 700 series, but there are some 500 and 800 devices in the mix.
We are probably going to make a trip to Ikea within the next month to get some furniture, and I was looking at their smart home devices and they have really good prices. Whether or not they are good devices... I have no idea. But after a little researching I realized all these devices are matter over thread. I don't have anything that is a thread border router, so I assume that just means I can't use any of it. When I Google "What can I use as a thread border router?" I see lists of devices that I do not plan on owning....
But I'm also confused about how Hubitat would even talk to the thread network. I know Matter is an application layer protocol, while thread is in the network layer. So I assume that Hubitat communicates with the thread border routers over IP (I assume locally) and tells it "tell device X to do Y" and the border router will send updates from the devices to Hubitat. But everything I've read about thread says it's best to have multiple border routers for redundancy. So that means buying even more devices that I wouldn't plan on buying otherwise... How does Hubitat know which border router to send a command to? Or does it send to all of them, something like multicast?
Honestly... it sorta makes me want to stick with zwave. The Ikea devices are very tempting though; especially the remote control.
Ikea's new Thread stuff seems to have some pretty widespread growing pains right now in terms of flaky performance... You can google around for more about that, but I expect they'll eventually sort it out.
A Thread Border Router acts as a bi-directional bridge between a Thread Mesh Network and your home LAN. Matter uses IPv6 (it creates its own private IPv6 network behind the scenes) that lives on top of Ethernet/WiFi/Thread.
Just like Zigbee and Z-Wave, Matter over Thread devices need multiple repeater-capable devices to strengthen the Thread Mesh Network. Since this requires non-sleepy devices to act as repeaters, the devices need to be mains-powered, just like for Zigbee and Z-Wave. The difference that I see is that most (not all) mains-powered Matter devices are “Matter over WiFi” devices, which do not help with strengthening the Thread mesh network at all. Thus, many people choose to add more AppleTV 4K’s, Google Home Hub’s, or Amazon Echo’s with built-in Thread Border Routers to help strengthen the Thread mesh network. Then the problem becomes possibly having multiple Thread mesh networks, one from each brand of devices, which do not help each other whatsoever. That problem is supposed to get better with Thread v1.4, which has been a slow rollout amongst the big three companies.
Right now, I would agree with you. Sticking with Zigbee, Z-Wave, and possibly Lutron will make for a solid smart home.
IMHO, Matter over WiFi devices are actually somewhat decent and reliable. Matter over Thread is a bit of the Wild West. It will improve over the coming years, but it has some maturing to do to get everything to work together smoothly. The new IKEA devices are a perfect example of just how much more maturing is required.
If you want to read about recent experiences of Hubitat users with those new IKEA devices, start here.
Some of the IKEA devices seem to have a ZigBee mode available. Their light bulbs, for instance, will switch to ZigBee mode if you turn The bulbs off and on 12 times. They don't advertise this in any of their documentation, but there are several reviewers which has stated this work around. Do a deep Google dive on the device your interested in before heading off to the store.
Hubitat's hardware solution is the C8 Pro Thread Special Edition hub. This hub replaces the Zigbee radio with a Thread radio, which then acts as a Thread Border Router and allows Matter over Thread (MoT) devices to be directly paired to the C8ProT hub. See discussion here.
Alternatively, many folks find that the AppleTV 4K (latest model with Ethernet + WiFi and 128GB of storage) has a very good Thread Border Router. Apple HomePod Mini's are also TBR's, but rely on WiFI for home network connectivity. Note: To use the AppleTV 4K solution, one does need to have an iPhone or iPad as well.
Some use Google's Home Hub or Amazon Echo devices. Amazon seems to be trailing behind the others when it comes to Matter Standards, though.
Some folks like to use an Aqara M3 hub.
Lots of options available. I personally have used the latest gen AppleTV 4K (make sure you don't buy the WiFi-only model, as it does not contain a Thread radio) as well as the Hubitat C8 Pro Thread hub. It is kind of nice having a native Hubitat solution as one can build out a private, dedicated Thread mesh network, very similar to how Zigbee works with the existing Hubitat hubs (i.e. no reliance on any other hardware vendors at all.)
