I have a Tapo Matter Color bulb on my front porch. Several different things control it. When I open the front door and it is after dark, or dusk, it comes on White. During the Christmas season starting at 5 pm it it rotates color every 10 seconds for several hours. All works great.
This morning when I checked my hub logs it was filled with about an hour and a half from 5 pm last night with the following error:
dev:33962025-12-27 06:40:12.079 PMerrorjava.lang.IllegalStateException: Queue full
dev:33962025-12-27 06:40:10.082 PMerrorjava.lang.IllegalStateException: Queue full
Went back and checked a camera recording and this is what I found. Apparently I opened the front door exactly at 5 pm (just by coincedence). So there were 2 commands to the light within a second or less. Apparently the bulb didn't like it. It stayed white and spewed the error for that hour and half then started changing color just like it should. I never happened to look out front and see that.
This was a rare occurence and probably never happen again. But just thought I would put the info out there that, what I assume, is too rapid a command change can mess it up.
