LAN device discovery fails to detect my Marantz SR6010 (network discovery is on and other devices can see it). Any tips?
I don't own a Marantz but read through this thread
It's supposed to be supported officially...
What do you see in the live logs when you try to connect to the receiver?
You may have to manually Add a Virtual Device, assign it the appropriate driver, and configure itโs settings. Iโm not sure Hubitat will auto-discover receivers.
That worked! I noticed there was no in-built Marantz driver but as i've seen from the forum, the Denon driver works fine.
