Hi @dan.t, I'm currently running MakerAPI in debug mode on my HomeBridge instance (v1.6.0) and I stumbled across this message:
[30/11/2022, 11:21:06] [Hubitat MakerAPI hhm:0.4.15] Got an unknown error code, 302 tell dan.t in the hubitat forums and give him the following dump <ref *2> IncomingMessage { _readableState: ReadableState { objectMode: false, highWaterMark: 16384, buffer: BufferList { head: null, tail: null, length: 0 }, length: 0, pipes: [], flowing: true, ended: true, endEmitted: true, reading: false, constructed: true, sync: false, needReadable: false, emittedReadable: false, readableListening: false, resumeScheduled: false, errorEmitted: false, emitClose: true, autoDestroy: true, destroyed: true, errored: null, closed: true, closeEmitted: true, defaultEncoding: 'utf8', awaitDrainWriters: null, multiAwaitDrain: false, readingMore: false, dataEmitted: false, decoder: null, encoding: null, [Symbol(kPaused)]: false }, _events: [Object: null prototype] { end: [ [Function: responseOnEnd], [Function (anonymous)] ], data: [Function (anonymous)] }, _eventsCount: 2, _maxListeners: undefined, socket: <ref *1> Socket { connecting: false, _hadError: false, _parent: null, _host: null, _readableState: ReadableState { objectMode: false, highWaterMark: 16384, buffer: BufferList { head: null, tail: null, length: 0 }, length: 0, pipes: [], flowing: true, ended: true, endEmitted: true, reading: false, constructed: true, sync: false, needReadable: false, emittedReadable: false, readableListening: false, resumeScheduled: false, errorEmitted: false, emitClose: false, autoDestroy: true, destroyed: true, errored: null, closed: true, closeEmitted: true, defaultEncoding: 'utf8', awaitDrainWriters: null, multiAwaitDrain: false, readingMore: false, dataEmitted: true, decoder: null, encoding: null, [Symbol(kPaused)]: false }, _events: [Object: null prototype] { end: [Array], free: [Function: onFree], close: [Array], timeout: [Function: onTimeout], agentRemove: [Function: onRemove], error: [Function: socketErrorListener], data: [Function: socketOnData], drain: [Function: ondrain] }, _eventsCount: 8, _maxListeners: undefined, _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: true, decodeStrings: false, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: false, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: false, autoDestroy: true, errored: null, closed: true, closeEmitted: true, [Symbol(kOnFinished)]: [] }, allowHalfOpen: false, _sockname: null, _pendingData: null, _pendingEncoding: '', server: null, _server: null, parser: null, _httpMessage: ClientRequest { _events: [Object: null prototype], _eventsCount: 2, _maxListeners: undefined, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Circular *1], _header: 'GET /installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19 HTTP/1.1\r\n' + 'Host: 192.168.0.227\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19', _ended: true, res: [Circular *2], aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.0.227', protocol: 'http:', [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype] }, write: [Function: writeAfterFIN], [Symbol(async_id_symbol)]: 2730607, [Symbol(kHandle)]: null, [Symbol(kSetNoDelay)]: false, [Symbol(lastWriteQueueSize)]: 0, [Symbol(timeout)]: null, [Symbol(kBuffer)]: null, [Symbol(kBufferCb)]: null, [Symbol(kBufferGen)]: null, [Symbol(kCapture)]: false, [Symbol(kBytesRead)]: 296, [Symbol(kBytesWritten)]: 150, [Symbol(RequestTimeout)]: undefined }, httpVersionMajor: 1, httpVersionMinor: 1, httpVersion: '1.1', complete: true, rawHeaders: [ 'Connection', 'close', 'Date', 'Wed, 30 Nov 2022 19:21:07 GMT', 'Set-Cookie', 'HUBSESSION=node01cgf6l5qjldagx3kviqlkilgb485.node0; Path=/', 'Expires', 'Thu, 01 Jan 1970 00:00:00 GMT', 'Location', 'http://192.168.0.227/login?loginRedirect=%2Finstalledapp%2Fconfigure%2F22%2FmainPage%2Fdevices' ], rawTrailers: [], aborted: false, upgrade: false, url: '', method: null, statusCode: 302, statusMessage: 'Found', client: <ref *1> Socket { connecting: false, _hadError: false, _parent: null, _host: null, _readableState: ReadableState { objectMode: false, highWaterMark: 16384, buffer: BufferList { head: null, tail: null, length: 0 }, length: 0, pipes: [], flowing: true, ended: true, endEmitted: true, reading: false, constructed: true, sync: false, needReadable: false, emittedReadable: false, readableListening: false, resumeScheduled: false, errorEmitted: false, emitClose: false, autoDestroy: true, destroyed: true, errored: null, closed: true, closeEmitted: true, defaultEncoding: 'utf8', awaitDrainWriters: null, multiAwaitDrain: false, readingMore: false, dataEmitted: true, decoder: null, encoding: null, [Symbol(kPaused)]: false }, _events: [Object: null prototype] { end: [Array], free: [Function: onFree], close: [Array], timeout: [Function: onTimeout], agentRemove: [Function: onRemove], error: [Function: socketErrorListener], data: [Function: socketOnData], drain: [Function: ondrain] }, _eventsCount: 8, _maxListeners: undefined, _writableState: WritableState { objectMode: false, highWaterMark: 16384, finalCalled: false, needDrain: false, ending: false, ended: false, finished: false, destroyed: true, decodeStrings: false, defaultEncoding: 'utf8', length: 0, writing: false, corked: 0, sync: false, bufferProcessing: false, onwrite: [Function: bound onwrite], writecb: null, writelen: 0, afterWriteTickInfo: null, buffered: [], bufferedIndex: 0, allBuffers: true, allNoop: true, pendingcb: 0, constructed: true, prefinished: false, errorEmitted: false, emitClose: false, autoDestroy: true, errored: null, closed: true, closeEmitted: true, [Symbol(kOnFinished)]: [] }, allowHalfOpen: false, _sockname: null, _pendingData: null, _pendingEncoding: '', server: null, _server: null, parser: null, _httpMessage: ClientRequest { _events: [Object: null prototype], _eventsCount: 2, _maxListeners: undefined, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: [Circular *1], _header: 'GET /installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19 HTTP/1.1\r\n' + 'Host: 192.168.0.227\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: [Agent], socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19', _ended: true, res: [Circular *2], aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.0.227', protocol: 'http:', [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype] }, write: [Function: writeAfterFIN], [Symbol(async_id_symbol)]: 2730607, [Symbol(kHandle)]: null, [Symbol(kSetNoDelay)]: false, [Symbol(lastWriteQueueSize)]: 0, [Symbol(timeout)]: null, [Symbol(kBuffer)]: null, [Symbol(kBufferCb)]: null, [Symbol(kBufferGen)]: null, [Symbol(kCapture)]: false, [Symbol(kBytesRead)]: 296, [Symbol(kBytesWritten)]: 150, [Symbol(RequestTimeout)]: undefined }, _consuming: true, _dumped: false, req: <ref *3> ClientRequest { _events: [Object: null prototype] { error: [Function (anonymous)], prefinish: [Function: requestOnPrefinish] }, _eventsCount: 2, _maxListeners: undefined, outputData: [], outputSize: 0, writable: true, destroyed: false, _last: true, chunkedEncoding: false, shouldKeepAlive: false, maxRequestsOnConnectionReached: false, _defaultKeepAlive: true, useChunkedEncodingByDefault: false, sendDate: false, _removedConnection: false, _removedContLen: false, _removedTE: false, _contentLength: 0, _hasBody: true, _trailer: '', finished: true, _headerSent: true, _closed: false, socket: <ref *1> Socket { connecting: false, _hadError: false, _parent: null, _host: null, _readableState: [ReadableState], _events: [Object: null prototype], _eventsCount: 8, _maxListeners: undefined, _writableState: [WritableState], allowHalfOpen: false, _sockname: null, _pendingData: null, _pendingEncoding: '', server: null, _server: null, parser: null, _httpMessage: [Circular *3], write: [Function: writeAfterFIN], [Symbol(async_id_symbol)]: 2730607, [Symbol(kHandle)]: null, [Symbol(kSetNoDelay)]: false, [Symbol(lastWriteQueueSize)]: 0, [Symbol(timeout)]: null, [Symbol(kBuffer)]: null, [Symbol(kBufferCb)]: null, [Symbol(kBufferGen)]: null, [Symbol(kCapture)]: false, [Symbol(kBytesRead)]: 296, [Symbol(kBytesWritten)]: 150, [Symbol(RequestTimeout)]: undefined }, _header: 'GET /installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19 HTTP/1.1\r\n' + 'Host: 192.168.0.227\r\n' + 'Connection: close\r\n' + '\r\n', _keepAliveTimeout: 0, _onPendingData: [Function: nop], agent: Agent { _events: [Object: null prototype], _eventsCount: 2, _maxListeners: undefined, defaultPort: 80, protocol: 'http:', options: [Object: null prototype], requests: [Object: null prototype] {}, sockets: [Object: null prototype], freeSockets: [Object: null prototype] {}, keepAliveMsecs: 1000, keepAlive: false, maxSockets: Infinity, maxFreeSockets: 256, scheduling: 'lifo', maxTotalSockets: Infinity, totalSocketCount: 1, [Symbol(kCapture)]: false }, socketPath: undefined, method: 'GET', maxHeaderSize: undefined, insecureHTTPParser: undefined, path: '/installedapp/configure/22/mainPage/devices?access_token=6f27390a-4cce-44e3-ac73-100ea9501a19', _ended: true, res: [Circular *2], aborted: false, timeoutCb: null, upgradeOrConnect: false, parser: null, maxHeadersCount: null, reusedSocket: false, host: '192.168.0.227', protocol: 'http:', [Symbol(kCapture)]: false, [Symbol(kNeedDrain)]: false, [Symbol(corked)]: 0, [Symbol(kOutHeaders)]: [Object: null prototype] { host: [Array] } }, [Symbol(kCapture)]: false, [Symbol(kHeaders)]: null, [Symbol(kHeadersCount)]: 10, [Symbol(kTrailers)]: null, [Symbol(kTrailersCount)]: 0, [Symbol(RequestTimeout)]: undefined }
Is there something I need to change on my end to address this?
Thanks!
