Hi,
I'm using the MakerAPI to fetch device info and noticed that it returns all attributes regardless if there's a 'null' value set or not. While maybe some devs are interested in just knowing that a device has an attribute or not - I would argue there's not much value in getting a null attribute and would rather not have it passed back at all to save payload size.
"name" : "Battery Voltage Interval",
"currentValue" : null,
"dataType" : "NUMBER"
I'm not requesting that MakerAPI make any default changes -- but what about a request param to ignore these null attributes?
Here's an example of 1 device response in the MakerAPI:
http://192.168.0.202/apps/api/38/devices/334
"id" : "359",
"name" : "Camera-88951",
"label" : "front door",
"attributes" :
"name" : "AC Power",
"dataType" : "BOOL"
"name" : "Account",
"name" : "Account ID",
"name" : "Alert Interval",
"name" : "Alert Repeat",
"dataType" : "STRING"
"name" : "Alert Tone Enable",
"dataType" : "BOOL"
"name" : "Alert Tone Volume",
"name" : "Arm String",
"name" : "Armed",
"dataType" : "BOOL"
"name" : "Auto Arm By Geo",
"dataType" : "BOOL"
"name" : "Auto Arm By Time",
"dataType" : "BOOL"
"name" : "Auto Test",
"dataType" : "BOOL"
"name" : "Backfill In Progress",
"name" : "Battery Alarm Enable",
"dataType" : "BOOL"
"name" : "Battery Alert Account",
"name" : "Battery Alert Count",
"name" : "Battery Alert Status",
"name" : "Battery Check Time",
"name" : "Battery Number",
"currentValue" : 3,
"name" : "Battery Status",
"currentValue" : "ok",
"name" : "Battery Voltage",
"currentValue" : 164,
"name" : "Battery Voltage Hysteresis",
"name" : "Battery VoltageThreshold",
"name" : "Busy",
"dataType" : "BOOL"
"name" : "Buzzer On",
"dataType" : "BOOL"
"name" : "Camera Error",
"dataType" : "BOOL"
"name" : "Camera ID",
"name" : "Camera Key",
"name" : "Camera Seq",
"name" : "Clip Bitrate",
"name" : "Clip Max Length",
"name" : "Clip Rate",
"name" : "Clip Seconds",
"name" : "Clip Warning Threshold",
"name" : "Continue Warning",
"name" : "Created",
"name" : "DHCP Failure Count",
"name" : "Daylight Savings Time",
"dataType" : "BOOL"
"name" : "Deleted",
"name" : "Dev 1",
"name" : "Dev 2",
"name" : "Dev 3",
"name" : "Early Notification",
"dataType" : "BOOL"
"name" : "Early Notification Compatible",
"dataType" : "BOOL"
"name" : "Early PIR Compatible",
"dataType" : "BOOL"
"name" : "Early Termination",
"dataType" : "BOOL"
"name" : "Early Termination Supported",
"dataType" : "BOOL"
"name" : "Enabled",
"dataType" : "BOOL"
"name" : "Encryption Key",
"name" : "Error Codes",
"name" : "FW Git Hash",
"name" : "Feature Plan ID",
"name" : "Firmware Version",
"name" : "Flip Image",
"dataType" : "BOOL"
"name" : "Flip Video",
"dataType" : "BOOL"
"name" : "Flip Video Compatible",
"dataType" : "BOOL"
"name" : "ID",
"name" : "IPv",
"name" : "Illuminator Duration",
"name" : "Illuminator Enable",
"name" : "Illuminator Intensity",
"name" : "Invert Image",
"dataType" : "BOOL"
"name" : "Issues",
"currentValue" : "[]",
"name" : "Join Available",
"dataType" : "BOOL"
"name" : "Join State",
"name" : "LFR 108 Wakeups",
"name" : "LFR Alert Count",
"name" : "LFR Channel",
"name" : "LFR Frequency",
"name" : "LFR Strength",
"currentValue" : 5,
"name" : "LFR Sync Interval",
"name" : "LFR TB Wakeups",
"name" : "Last Activity",
"name" : "Last Backfill Completed",
"name" : "Last Backup Completed",
"name" : "Last Backup Started",
"name" : "Last Command ID",
"name" : "Last HB",
"name" : "Last LFR Alert",
"name" : "Last Snapshot Event",
"name" : "Last Temp Alert",
"name" : "Last Wifi Alert",
"name" : "Lifetime Count",
"name" : "Lifetime Duration",
"name" : "Light Sensor CH0",
"name" : "Light Sensor CH1",
"name" : "Light Sensor Data New",
"dataType" : "BOOL"
"name" : "Light Sensor Data Valid",
"dataType" : "BOOL"
"name" : "LiveView Continue Interval",
"name" : "LiveView Duration",
"name" : "LiveView Enabled",
"dataType" : "BOOL"
"name" : "LiveView Mode",
"name" : "LiveView RSTP",
"name" : "LiveView Rate",
"name" : "LiveView Seconds",
"name" : "Liveview Bitrate",
"name" : "Local Storage Compatible",
"dataType" : "BOOL"
"name" : "Local Storage Enabled",
"dataType" : "BOOL"
"name" : "Local Storage Status",
"name" : "MAC Address",
"name" : "MFG Main Range",
"name" : "MFG Main Type",
"name" : "MFG Mez Range",
"name" : "Manufacturer Mez Type",
"name" : "Max Resolution",
"name" : "Media ID",
"name" : "Motion Detection Enabled",
"currentValue" : "true",
"dataType" : "BOOL"
"name" : "Motion Regions",
"name" : "Motion Regions Compatible",
"dataType" : "BOOL"
"name" : "Motion Sensitivity",
"name" : "Name",
"currentValue" : "front door",
"name" : "Network ID",
"currentValue" : 39640,
"name" : "Network Key",
"name" : "Network Origin",
"name" : "NetworkID",
"name" : "New Command",
"dataType" : "BOOL"
"name" : "Night Vision Exposure",
"name" : "Night Vision Exposure Compatible",
"dataType" : "BOOL"
"name" : "OS Version",
"name" : "Offline Alert Count",
"name" : "Onboarded",
"dataType" : "BOOL"
"name" : "Options",
"dataType" : "MAP"
"name" : "PIR Rejections",
"name" : "Ping Interval",
"name" : "Privacy Zones Compatible",
"dataType" : "BOOL"
"name" : "Record Audio",
"dataType" : "BOOL"
"name" : "Record Audio Enable",
"dataType" : "BOOL"
"name" : "Retry Count",
"name" : "SM Backup Enabled",
"dataType" : "BOOL"
"name" : "Serial",
"name" : "Server",
"name" : "Siren Enable",
"dataType" : "BOOL"
"name" : "Siren Volume",
"name" : "Snapshot Compatible",
"dataType" : "BOOL"
"name" : "Snapshot Enabled",
"dataType" : "BOOL"
"name" : "Snapshot Period Minutes Options",
"dataType" : "LIST"
"name" : "Socket Failure Count",
"name" : "Status",
"currentValue" : "done",
"name" : "Status",
"name" : "Storage Total",
"name" : "Storage Used",
"name" : "Submit Logs",
"dataType" : "BOOL"
"name" : "Sync Module Error",
"dataType" : "BOOL"
"name" : "Sync Module ID",
"name" : "Table Update Sequence",
"name" : "Temp Adjust",
"name" : "Temp Alarm Enable",
"dataType" : "BOOL"
"name" : "Temp Alert State",
"name" : "Temp Alert Status",
"dataType" : "BOOL"
"name" : "Temp Alerts Enabled",
"dataType" : "BOOL"
"name" : "Temp Hysteresis",
"name" : "Temp Interval",
"name" : "Temp Max",
"name" : "Temp Min",
"name" : "Temperature Alert Count",
"name" : "Thumbnail",
"name" : "Thumbnail File",
"currentValue" : "fw_7.96__Zi7psW4H_2020_09_18__12_44PM.jpg",
"name" : "Thumbnail Image",
"name" : "Time 108 Boot",
"name" : "Time DHCP Lease",
"name" : "Time DNS Resolve",
"name" : "Time First Video",
"name" : "Time WLAN Connect",
"name" : "Time Zone",
"name" : "Total 108 Wakeups",
"name" : "Total TB Wakeups",
"name" : "Type",
"currentValue" : "xt2",
"name" : "Unit Number",
"name" : "Updated",
"currentValue" : "2020-09-28T14:27:59+00:00",
"name" : "Usage",
"name" : "Usage Rate",
"currentValue" : "false",
"dataType" : "BOOL"
"name" : "Video Description",
"name" : "Video History Count",
"name" : "Video Length",
"name" : "Video Quality",
"name" : "Video Recording Enable",
"dataType" : "BOOL"
"name" : "Video Recording Optional",
"dataType" : "BOOL"
"name" : "Video hz",
"name" : "WiFi Connect Failure Count",
"name" : "WiFi Strength",
"currentValue" : -53,
"name" : "WiFi Timeout",
"name" : "Wifi Alert Count",
"name" : "battery",
"name" : "html",
"name" : "temperature",
"currentValue" : 77,
"capabilities" :
"TemperatureMeasurement",
"attributes" :
"dataType" : null
"Battery",
"attributes" :
"name" : "battery",
"dataType" : null
"Sensor",
"Actuator"
"commands" :
"ArmSystem",
"DisableMotionDetection",
"DisarmSystem",
"EnableMotionDetection"
